nitrous lines... earl's pro lite 350 hold nitrous pressure??
I'm looking at doing a pretty smooth appearing nitrous kit. I'm going to replace my fuel lines with the earl's pro lite 350 black nylon hose for a cleaner, less blingy appearance, while still being able to use AN fittings for the nice touch. I'm hoping i can use this same line for the nitrous side of the kit. this way it will blend in a lot better. I'm just not sure if it will hold 1000psi like nitrous pressure can exceed. I'm looking, but don't see any definate answer to that.
Re: nitrous lines... earl's pro lite 350 hold nitrous pressure??
Definitely not suitable for nitrous:
The new Earl's Pro-Lite 350™ hose is one of the lightest and most durable hoses available on the market today! Serious racers, from the professional oval or drag racer down to the bracket or Saturday night sportsman racer can benefit from the ultra light weight, durability and temperature characteristics of the NEW Pro-Lite 350™ hose.
With a maximum pressure rating of 350 psi and an operating temperature range of -40° F to +300° F, the Pro-Lite 350™ hose can take the most demanding conditions and still deliver you to the winners circle.
We have custom hoses available in a few color choices, which are suitable for both fuel & nitrous:
http://www.harrisspeedworks.com/shop/home.php?cat=261
Matt
Matt
stockssn2o
05-25-2015 08:54 AM
