longer throttle body bolts?
Old Oct 17, 2006 | 09:30 PM
F(ast)-body's Avatar
well as you know, with the nitrous plate inserted between the throttle body and the manifold the bolts aren't nearly long enough now I have a BBK throttle body)...to make the problem worse I can only use the Allen head on the bottem two since there is no room for the wider hex head....using the bolts I had only 3-4 threads are actually making contact with the manifold.....looked everywhere for 3" metric bolts with Allen head and no one seems to have them....what did you guys do?
Old Oct 17, 2006 | 09:56 PM
bowtiepwr's Avatar
Re: longer throttle body bolts?
>I have a BBK/Edlebrock 58mm with the Nitrous Works plate system and it came with longer bolts.
I can't remember which company had the longer throttle body bolts, but you could contact both and purchase them through either company.
Old Oct 17, 2006 | 10:33 PM
69z-28's Avatar
i remember when the guy i got my t/a from pulled the plate off, he had to find the stock bolts and remove the bolts included with the nitrous works kit. call them up, or head over to the hardware store.
Old Oct 18, 2006 | 09:22 PM
yeah the kit came with longer bolts...the problem I ran into is that the head on the hex head bolts that came with the nitrous kit are too big to fit the bottom bolt holes on the throttle body...the space is too narrow. BBK sent the Allen head bolts with the TB but they don't have anything longer...I need 3" bolts to make it work.....thought maybe someone else may have had the same problem....
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
