Mallory 685/MSD Wiring
Old Dec 25, 2006 | 11:52 PM
69gto96z's Avatar
Is this the correct harness to hook up a Mallory 685 box to my 96 TA?
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 26, 2006 | 12:36 AM
Sinister95Z's Avatar
That is the exact same one I used for my 95 Z. Worked like a charm.
Old Dec 26, 2006 | 09:05 AM
69z-28's Avatar
i will be ordering this to go with my mallory very soon. one question tho....
this is the mallory i want correct...http://www.jegs.com/webapp/wcs/store...18101_-1_10385
i cant wait to get this **** installed with my nitrous kit.hehehehehe
Old Dec 26, 2006 | 09:25 AM
69gto96z's Avatar
That is the same one I will be getting for my nitrous kit. What kind of kit are you going with? I am going to be using a Harris Speed Works wet.
Old Dec 26, 2006 | 04:24 PM
2000GTP's Avatar
Both the harness and box you have links to are correct for your application.
Old Dec 27, 2006 | 09:24 PM
97formulakid's Avatar
That's the box you want. I love mine. Easy adjustability and works like a charm.
Old Dec 28, 2006 | 02:20 AM
Daniel6718's Avatar
mount it in the glovebox like me too...then you can adjust window and timing on the fly...
Old Dec 28, 2006 | 08:29 AM
69gto96z's Avatar
Yeah I was gonna mount it just like you have yours. I ordered it the other day, and I am ordering my n2o kit hopefully friday, so I will hopefully have it here to install next weekend!
Old Dec 28, 2006 | 11:06 PM
69z-28's Avatar
ive heard of heat problems with the ignition box in the glovebox. thoughts....
Old Dec 29, 2006 | 02:02 AM
Daniel6718's Avatar
nah...idk mine doesnt seem to be that hot...and the glovebox isnt ventillation free...
Old Dec 29, 2006 | 04:58 AM
01Z's Avatar
01Z
Mine is in the glove box but I only have it connected for nitrous. Otherwise I use the harness Bypass Connector pigtail. In other words it is off (and cold) and out of the circuit most of the time. Once I read that these CDI spark intensifiers affect the life of the opti-spark I decided to have mine connected only when I need the spark control features. I even put a light in my control panel to tell me when I'm hooked up.
Old Dec 29, 2006 | 08:13 AM
69gto96z's Avatar
How did you do that? That may be an idea for me since my car is my daily. Maybe I can wire the power wire into my arming switch, so when I arm the nitrous, my box turns on?
Old Jan 1, 2007 | 03:10 PM
The Mallory 685 comes with a bypass connector. If you ever want to go back to stock, all you have to do is plug it in. Smart people over there at Mallory.
Old Jan 2, 2007 | 01:12 PM
2000GTP's Avatar
I routed my box all the way in the trunk, it keeps plenty cool back there and keeps the free space available in my glovebox.
Old Jan 2, 2007 | 06:34 PM
CamaroSS30thAnn's Avatar
my box is mounted right where the CAI goes since i have teh Ram Air
its pretty cool position i think and it keeps most the wires short.
which reminds me i have to clean up some of the wires , for a cleaner looking install
