What Window switch are you guys running?
Hey, just curious as to what window switch you guys are running and why?
Also, let me know which full throttle sensor you are running if you are running that as well. Thanks!!
Re: What Window switch are you guys running?
I'm using the Mallory 685 ignition box which has the built-in window switch as well as a timing retard function. As for the throttle switch, I am using the mechanical WOT switch that mounts on the throttle body and is depressed when the throttle is fully open.
