View Full Version : N2O Tech
- How much N20 on my new 383?
- Quick! I need opinions on Compucar kit......
- are there any 50hp ls1 kits available?
- Holley 190lph pump??
- how much N20 on a stock 4L60e?
- New to Nitrous. How much can an OEM 400 block with this bottom end handle?
- NX Switch panal ????'s
- The problem is in the plugs ?
- Am I pushing it?
- Better to go 2 stage or 1 stage with basically stock motor?
- Wet NOS with EFI - A couple of Questions
- Window switch or WOT with 3000rpm stall?
- Anyone ever have this problem with Zex?
- Nitrous Works Installation Instructions?!?
- Using NX shark nozzle w/ Vortech Elbow, opinions please
- Max NX HP jets
- why are platinum plugs bad for N20
- n20 problem???
- Bottle location
- ZEX LT1 kit.. Opinions?
- Nitrous Buildup... for 200 shot?
- Is there a NX combo for 125hp shot?
- Compucar kit...want to run 75 shot...what jets?
- N20 Tech
- Jimmy Jams Activation switch
- Dry 150 Shot..
- Whats wrong with my bottle?
- Am i crazy or is this ok
- 150 pills on NOS kit are???
- NOS 5176 on a LS1?
- platinum plugs and 100 shot wet kit
- N20 and plugs
- plugs and N20
- Tried a Shark nozzle and 175 jets today...
- need help getting fuel
- retarding timing with 100-125 shot?
- Anybody know where I can get a 3an to 3an fitting
- n2o newbie question inside
- Basic Beginner N2O kit?
- what is more dangerous to...
- need 175 nx jets
- heads and cam plus nitrous questions
- n20 problems, need help
- hesitation
- Nos Refill Station
- Where should a 150 HP NX kit put me?
- nitrous uping jets what do u think?
- difference between dry and wet kit
- Stock 1995 Z & Nitrous
- Where does the grey wire go? (MSD8982)
- stock lt-1 goes 11.52 for $1300
- Spark plugg gap?
- thinking about N20
- Nitrous Install Pics
- quick question on N20...
- Is N2O socially acceptable?
- Co2 with N20
- Hooking up wet kit ??????'s
- LT4 Knock module with Nitrous
- differances in nozzles
- cc306 with Gas???
- spraying while on a 2 step rev limiter ?
- Nitrous Works Kit ATTN: Speedtechnologies
- NEW DRY KIT 50-400hp
- How long does the bottle last?
- Opinions on bringing in the squeeze... 150...9
- N2O for Bracket racing??
- NX solenoid max flow?
- nitrous works jet sizes
- Nitrous throw maf vs elbow vs tb plate?
- Off the shelf Octane bossters
- purge locations?
- Lean spike on my dry kit... Any input..
- Small dry kit or small wet kit
- Gemini Quad???
- TNT 150 shot
- Damn nitrous help!!
- Why no purge??
- going to track this weekend and i will be spraying?
- Dyno'd on the juice today, evaluate please...
- 150 shot = 10.3@129
- Edelbrock nitrous kits??
- 2 question please help.
- Lt4 hot cam kit and nitrous...any good??
- Pic of black intake w/ nos fogger?
- Having problems with Mallory 685
- I played it safe. What should I increase to?
- What do i need
- Dyno Result: 99 vette w/ 150shot
- Please help with MSD8982 install..
- Need research information
- 306cam vs 224/236 cam for n20
- Pulling fiming question...
- What brand??
- just finished my comucar install
- help my nitrous 75hp shot feels like 30hp
- A/F question while spraying my car....
- PICS, need PICS, install, and bottle mounting between rear seats
- Need nitrous lines/intercooler mount/solenoid...Where to get?
- Who here has chromed ot their bottle, or knows how
- 3 gallons on 100 octane gas will be ok with 150 shot??
- 5176 dry kit jet question...
- Please post your 383 N20 videos here
- Detonation factors?
- What fuel to run?? Please..Need answer today
- Too old?
- stock 3.8 with nitrous
- Launching with nitrous..... How many do it?
- NOS bottle heater wiring... Help please..
- When should I spray?
- WHat's safe for an LS1
- Dry or Wet???
- N20 Popping up high
- nx 100 shot expected et gain?
- Bottle heater pressure switch question.
- Zex Problem
- non-f-bod question: ZZ4 and Nitrous?
- KTamez
- Can you disassemble a Compucar TB plate?
- Popular 355 Buildup choices??
- fuel/ignition requirements?
- What else??
- Bottle mounting/ solenoid mounting
- stock tune+cam+n20
- Camshaft Selection
- Where can iget these replacement parts??
- Alternative to Progressive Controller?
- Knocking
- Which is easier on engine, NOS or supercharger?
- 383 Compression ?s
- Ring gap on LT1's??? Can it handle a 150hp shot?
- Whats your opinion on this system?
- Need spark plug part #'s for 2-3 steps colder
- opinions on spark plug probs on spray
- New track times
- NX Wet Kit with vortech elbow
- dry sex sucks how is dry zex
- Micro Switch For Second Stage With M6??
- need to trade FIPK filters
- Zex Jet Help PLZ
- New times with xtream 224/230&N20
- For Fun- Lets see some bad a$$ N20 set ups
- Who's been shooting the longest???
- ring gap?
- hypertech power programming and n2o
- MSD Digital 6
- How often do you guye change your
- Whos got the quickest LT1 n20 car
- Nitrous and 10:1 compression
- LS1 Injectors?
- Need some Direct port xperts
- car feels a tad faster after n2o use??
- Where Did You Mount The Solenoids?
- what rpm and speed trapping at?
- Nitrous setup for a lt1
- what NOS should Me get??
- Accel Ignition Timing Computer...
- Can someone give me the jet chart for the NX wet kit?
- Best cam to use for my setup on N20?
- 224/236 users in here
- What type of mix to get optimal octane for srpay??
- Most amount of N20 u can spray on an LT1
- leaking NW fuel solenoid... what to do?
- 100 shot worth worry about timing retard...
- Biggest Shot You Guys Think Is Safe For TR6 Plugs??
- Could I change my shark nozzle to a plate system?
- Anybody running 175 shot on there NX EFI Wet Kit?
- Second stage with horn button???
- is comucars lt1 kit a wet or dry kit?
- LT1...How often do you change plugs...
- nos cam?
- Spray with cutout open or closed?
- need help with intank fuel pump...scared to install
- fuel requirements
- NOS curious
- No liquid Nitrous from purge?????
- Dangerous to mount wet kit in donkey dong?
- N20 and porting the heads??
- window rpms
- Need part numbers for NX products
- First Time Nos
- Can I use a generic GM EFI kit?
- My winter prject
- ported heads/stock cam/fully forged bottom end??
- Spay on stock plugs???? good.... bad???
- Plate vs ummm other????
- FPSS? Who is surging/Who is not?
- Will a generic GM EFI kit work?
- why do my rpms take a split second to fall after using juice??
- 15 lb tank bracket dimensions
- TNT vs NX
- setting window switch below 3K rpm??
- High mileage LT1's on the spray
- Ran N20 for the first time....does this sound right. Experts please help!!
- ZEX for LS1 SS
- Best additions to NX kit?
- What is the smallest nitrous shot I can get?
- Nitrous Surges on Full Bottle, Help
- Anyone using the Wilson efi kit?
- Looking for a NX kit with all the options
- What about TR5 ??
- Stall converter and nitrous
- NOS 5177 System Instructions
- do i need a strong bottom end or top end for large nitrous??
- What cam are you nitrous guys using?
- NX dual stage... MSD digital 6+, 2 RPM window....????
- Strange(maybe)N2O Problem
- Does nitrous have an effect on manifold absolute pressure?
- NX price increase and upcoming new products!
- NX Kit LT1
- is it the right one for me?
- What jetting and fuel pressure for a a completly dry shot for a LT1.
- how much N20 on a stock LT1?
- convertor,cam and gear setup for nitrous
- Nx wet kit (20920-00) what all do I need???
- direct port setup
- Fuel and NOS Pressure gauges?
- Help with Zex kit
- NX jet question
- need help with 100 shot NX wet shot jets
- How do you tell the diff between a 125 jet and other jets?
- Any pics of bottle mounted on hump?
- Where to buy Compucar N20 kits??
- Nitrous Oxide 101
- Nitrous
- How long is too long for bottle heater?
- Fuel Pressure Safety Switch (Hobbs Sensor) Install on an LT1?
- Installing NX wet system this weekend...any tips?
- Just curious, what size shot would you recommend?
- ZEX Lt1 kit....anyone running it?
- Timing Retard on Scanmaster??
- How is the NW's LT1 system
- NOS tutorial/help?
- anybody cover their nitrous lines??
- leaking fuel solenoid...help!!!
- ??need special engine assembly procedure for N20??
- NOS + stock LS1 motor
- Wide open throttle switch install
- Suggest a Nitrous cam for 300 shot
- Modified MSD Window Switches now available!
- Anyone running the Nitrous Works Wet Plate system?
- Leaking Solenoid??
- Best Timing Retard Box??
- nos on single turbo
- biggest shot on stock bottom lt1
- wiring question
- How much power adder can forged parts handle?
- nx relay question?????????
- solenoid ?
- Disabling FPSS…
