Damn they were tight
Old Mar 8, 2005 | 05:21 PM
angel71rs's Avatar
Angry Damn they were tight
Did the spark plugs on the 98 today. Just over 50k on the originals. Actually pretty decent room to get at them with the air pipes/coil packs out of the way. Much more than on my last daily driver, an 89 Formula 350. Only removed the 1st 3 coil packs on the passenger side.
Problem was the tighest spark plugs I have ever run across in 20+ years of wrenching on cars.
You would have thought GM learned their lesson with the seized up spark plugs on the L88/L89 aluminum heads of the 60s. I guess not. Antiseize must be verboten at the General.
A swivel ratchet didn't have enough leverage to get it done. So I went to my swivel tip 3/8" drive breaker bar. Still no go. Had to put a cheater pipe on the breaker bar to get them to pop loose with a loud CRACK. When it happened on the 1st plug, I thought it was going to come out with threads for sure. Luckily all came out ok.
And what others have said about the factory plugs being junk is 100% accurate. Half had missing discs. Whoever at GM decided they could go 100k/miles needs to drop the crack pipe.
So anyone know why GM doesn't avail itself of anitseize?
Old Mar 8, 2005 | 05:35 PM
ss00's Avatar
Re: Damn they were tight
The GM bean-counters said no to antisieze on the plugs because it saved a couple of tenths of a cent per car produced.
Old Mar 13, 2005 | 05:54 PM
mebanditws6's Avatar
I changed my plugs at 70k miles, and none of them were nearly that tight. They were all about where they should be, tight, but nothing a regular wrench can't handle.
Jason
Old Mar 18, 2005 | 07:09 AM
locrain's Avatar
i'm getting a 2000 w/95k on it. i want to change them, but i have heard it is really hard. ???
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
Boss002
Jul 24, 2015 10:47 AM
Noct
Jul 14, 2015 01:18 AM
cmsmith
Jul 5, 2015 07:23 PM
