My Tires Rub
My Tires Rub
i was told i should get spacers, but i only need them in the back, can i do that? I need spacers for the rear zo6 rims i got, with 56mm offset, front is 54, front is fine tho, back rubs , will it ride or look off if i get the 1/4 inch spacer just in the back?
Re: My Tires Rub
ok well for some reason, mine are, u have little tires, 275? thats why yours fit. either way, do you know what i mean, will it look weird or no? i took off my wheels, and u can see on the tire and inside wheel well that it is rubbing
Re: My Tires Rub
Yea, you should probably go with the 5/16 spacer, which is what most people use with the 295's and work pretty well. And how are your studs, are they long enough, sometimes you need longer ones, b/c stock ones only thread 75% in some cases. And I dont think the offset will look out of place or anything.
Re: My Tires Rub
I'm getting 17x11 in the back with 315's and 17x9.5 in the front with 275's. I know I'll probably rub, I'll need the BFH mod though
And possibly some spacers. I'll also lower it about an inch as well.
Re: My Tires Rub
Originally Posted by Chris_Camaro
about how much to get that painted, im thinkin about getting the ss spoiler, and maybe ss hood, or the one you got, that thing looks sick
Re: My Tires Rub
Why are you using so much tire on a car with no power? Is it a looks thing? If so, why are you posting on the LS1 section and not in the V6 section. Not to sound mean or anything, just that I dont personally agree with putting that much tire on a car that wont need it.
Most LS1's dont need that much tire.. takes some serious modding to need more than the stock rubber.
Re: My Tires Rub
wow, well since i needed to know, i posted here, v6 tech, and suspension also, im throwin on a turbo in the next 8 months, got a sweet deal on the rims. im 18 also, whats ur insurance? not as much as mine i bet, what do you do? somthin that pays u more i bet, what im getting at is, i know my car doesnt have the power like the ls1, so i just have fun with what i got, no need in tellin me it has no power. but then again, that ss last week thought different..... later
colts0455
13
Aug 7, 2015 09:15 PM
