SLP Loudmouth vs SLP Loudmouth II
Has anyone heard them both and if so which sounds better in your opinion? Also if anyone knows where i can find sound clips of the Loudmouth II please let me know cause LS1 Sounds does not have it as far as i could tell. Anyone think the GMMG sounds better than both of the?
Guest
Posts: n/a
Re: SLP Loudmouth vs SLP Loudmouth II
Originally Posted by ztwenty8
so is the LMII more restrictive since its a muffler now? and its suspoesed quieter?
Shouldn't be any more restrictive.
If you have the cash for a GMMG, you might as well get true duals.
true duals do sound good though
sound clips-www.ls1sounds.com Loudmouth II can also be found @ www.ls1speed.com --and Yes, I have also heard that the GMMG has a NICE muscle car sound all the way through the power band, but is pricey.
Originally Posted by unvc92camarors
i guess it depends on emissions in your area (if you have them), and how much ground clearance you need
Do a search for Bassani duals for an idea. I've seen it done like this but with 2 mufflers at the back like Vettes used to run. I've also seen the tubes ran under the rear axel. Didn't care for that though.
Could also run a pair of chambered sticks in the piping.
tommalcolm
Sep 11, 2015 03:39 PM
