pro 5.0 shifter too tall....
Old Feb 11, 2005 | 05:03 AM
evo.end3R's Avatar
What can i do to make it shorter in height???
Old Feb 11, 2005 | 08:48 AM
Flaminchiten67's Avatar
Re: pro 5.0 shifter too tall....
Cut about an inch off the threads.
Old Feb 11, 2005 | 08:56 AM
'99 SS's Avatar
I installed 'Lou's Short Stick' on my PRO 5.O
Old Feb 11, 2005 | 10:54 AM
silv3rsw33t's Avatar
Same here, I bought Lou's short stick and its awesome!
Old Feb 11, 2005 | 11:20 AM
stereomandan's Avatar
Ditto, I cut about 1.25" off my threads and it's plenty short now. Sometimes I almost wonder if it's too short.
Dan
Old Feb 11, 2005 | 11:39 AM
Ken S's Avatar
unless they changed the design, there ever should be a notch in the middle of the threads to lop off about an inch... its real easy to do.. can even do it with a hacksaw.
Old Feb 11, 2005 | 02:52 PM
evo.end3R's Avatar
lous short stick? where do i get that?
Old Feb 11, 2005 | 03:03 PM
'99 SS's Avatar
www.afterthoughtsauto.com
You probably can locate it elsewhere, but I did a search, and I've ordered from Afterthoughtsauto before, and they're good.
One of my best mods, the PRO 5.O w/ the short stick
Old Feb 11, 2005 | 03:22 PM
Shempy's Avatar
So did I. Dropped it off at a machine shop and they cut off the excess thread.
Old Feb 11, 2005 | 05:00 PM
SS1LE02's Avatar
Get the Qwik Stick. Here's a link from one of the sponsors of this board.
http://www.speedspecialty.com/store/...duct=QuikStick
Old Feb 12, 2005 | 05:06 AM
D James's Avatar
just cut it with a hacksaw it cuts real fast, but put a nut on it first below the cut, this will rethread the cut. otherwise you can't screw on the shifter ****. I bought one from the hardware store for 0 cents, then screwed it on all the wway and measured on inch down, and cut then unscrewed the nut and installed the shifter. Its very easy, and its perfect I wouldn't want it any shorter or taller, its just right. Getting the short stick is better suited for some other shifter that doesn't have access threads to remove.
Old Feb 12, 2005 | 07:40 AM
evo.end3R's Avatar
hmm.. i have "bought" nuts an screws from homedepot for 0 cents before too...
Old Feb 12, 2005 | 09:28 AM
XTZ's Avatar
XTZ
I've got the Qwik Stick also. For the money, it's one of the best mods I've done.
blac94Z
Nov 4, 2015 01:59 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
