What gears do i have??
Old Feb 11, 2005 | 06:34 PM
sunsetorangess's Avatar
Exclamation What gears do i have??
I run at 2000 rpms at 85mph. Can you guys help me out and tell me what gears i have, and how these gears will perform with a 224/224-114LSA cam. Thanks.
Old Feb 11, 2005 | 06:49 PM
chris mac's Avatar
Re: What gears do i have??
3.42's. they'll work just fine with that cam. you could always go to 4.10's, but the stockers will work well for ya.
good luck
Old Feb 11, 2005 | 06:53 PM
96SFLZ's Avatar
Sounds like 3.42's to me.
That's not a high rpm cam (IOW it should still make good power down low) so I'd think that they should work pretty well with it.
Old Feb 11, 2005 | 07:17 PM
MustangEater82's Avatar
if you want to be sure... check the option codes(either in the glove box, or doorjam)
look for a code GUX X being a number
GU4=3.08(not sure ever offered on z28s)
GU5=3.23
GU6=3.42
and I think GU3 is 2.73s but not sure.
but I am pretty sure the 6-speeds came with 3.42s...
Old Feb 11, 2005 | 07:43 PM
94ZRiCeKiLr's Avatar
GU5=3.23
GU6=3.42
2.73 is GU2 but if it's a M6 then you're correct in assuming it's a 3.42 car. they all are.
Old Feb 11, 2005 | 07:52 PM
Thanks guys!!
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
