compression test.....
Old Mar 2, 2005 | 02:40 PM
teke184's Avatar
first off...stock LS1...
what should the compression in PSI be on each cylinder?
second...
i have a misfire problem, think it's a bad lifter. it is intermitant...misses on cylinder 7 for a few seconds, then runs fine...then misses again...etc.
can i just pull the sparkplug, put the compression guage on it and run the engine to test compression? should i unplug that injector?
or should i just test it by turning it over with the starter?
i'm worried that if i just do the starter it could be reading the time when it seems to NOT miss...
if i run it i should be able to watch it fluctuate (assuming it IS a bad lifter) from proper compression to a period of bad compression.
any help would be greatly appreciated
Old Mar 3, 2005 | 10:21 AM
shouldaboughtthez's Avatar
Re: compression test.....
I don't think you run the car to do a compression test. I believe you bump the motor over.
Can you pull the valve cover off and watch the pushrods move up and down? Making sure the lifters are moving correctly?
Old Mar 3, 2005 | 11:04 PM
Capn Pete's Avatar
If a valve is bent though, you won't see it just by watching the valves and lifters moving. I don't think that tiny difference would be visible to the naked eye?
Old Mar 4, 2005 | 06:19 AM
teke184's Avatar
thanks guys..
did the compression test...
180psi on 3
170ish on 5 (sometimes missed on this cylinder)
000psi on 7 (major misses on this one)
so i guess it answers my question...bad lifter
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
