Engine belt Q
Old Feb 13, 2005 | 12:07 PM
roadkillZ28's Avatar
Engine belt Q
When I spouse to replace the engine belt?
Is the tension belt already supported with spring in LS1.. or I have to do it myself for new one?
thanks ...
Old Feb 13, 2005 | 01:44 PM
stone4779's Avatar
Re: Engine belt Q
I would replace it if you have over 40K miles or so...I replaced both of mine at 25K...nothing wrong with the stockers but I already had them off so I figured why not while I was there...
To take off the belt just take a ratchet wrench and the appropriate socket and put it on the bolt in the center of the tensioner pulley on the passenger side of the engine and put pressure on it (clockwise) and it will give you enough slack to slide the belt off of the tensioner.
Old Feb 14, 2005 | 06:09 AM
Re: Engine belt Q
Thanx man for this explanation
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
dale3in98
Feb 14, 2015 12:18 PM
siguy
Nov 27, 2014 10:07 AM
Snoman73
Nov 17, 2014 07:22 PM
