First Mods but now I have stalling??!!
Old Feb 9, 2005 | 11:20 AM
poxz's Avatar
I completed my first mod last night. It was an slp lid with a K&N and I also did the free ram-air mod. I also cleaned off all the crap hiding under the old lid.
The car Runs ALOT better and it feels alot stronger, BUT..... It idles realy low now and it has already stalled 3 times. (at lights)
Any Ideas???
Oh P.S. the air hose is to short to reach the lid. I am getting that fixed today could that be the reason? And should i just extend the hose or by a separate filter for the hose???
Old Feb 9, 2005 | 01:16 PM
Strahley's Avatar
Re: First Mods but now I have stalling??!!
How much did you remove doing the free ram air?
Old Feb 9, 2005 | 01:30 PM
poxz's Avatar
I have a camaro mag that showed what to remove. I removed the cross and excess plastic. So now there is no plastic under the K&N.
Old Feb 9, 2005 | 05:45 PM
Greed4Speed's Avatar
I would think the K&N needs the cross piece to not bow.
Check your MAF and IAT connections for the stall.
Old Feb 9, 2005 | 07:04 PM
BirchMan98z's Avatar
Give your car a couple days to relearn its curve.
Old Feb 9, 2005 | 07:32 PM
poxz's Avatar
Yeah I don't think the person who owned it before me even cleaned under the hood. My car hasn't been able to breath in a while.
Old Feb 10, 2005 | 12:00 AM
also remember that if your car is getting TOO much air, it will die.
Old Feb 10, 2005 | 08:06 AM
shouldaboughtthez's Avatar
Are you getting an SES light? I have done this same mod and have not had any problems at all. But I did leave the cross piece under the filter in. Did you plug in the MAF and IAT sensors? If they are plugged in, try reseting the computer.
Here is how:
1. Turn key to the "on" position but don't start car
2. Pull the PCM BAT and PCM IGN fuses in engine compartment
3. Wait approximately 5 minutes
4. Turn ignition off
5. Replace fuses
6. Start the car and then make sure the light has gone off
A good place to start free mods and other mods is:
http://www.installuniversity.com/ins...sity/index.htm
Old Feb 10, 2005 | 09:56 AM
DanBUCF's Avatar
You don't need the cross piece under the filter...I removed it on my car and the 4 others that I've done that mod on...they're fine. When I dod the FRA mod, I actually do it a little different so it creates a bit of a vaccum going into the lid.
Old Feb 10, 2005 | 03:07 PM
35thZ282002's Avatar
My car did the same thing when I did that mod. Your suppose to make sure the battery is unplugged before you do that and then I just let my car run for about 15 minutes took it for a test drive and now everything seems fine....
Old Feb 11, 2005 | 12:02 PM
poxz's Avatar
I FOUND THE PROBLEM! The Egr was cut too short so it was creating a vacume leak. I was going to replace it(at @ nice $85) but I read you can take out the whole egr system and the A.I.R. system without hurting the car. + I'll loose 15lbs.
Old Feb 11, 2005 | 02:23 PM
Strahley's Avatar
If you removed ALL of the plastic, that's probably the problem. Way too much air without a proper tune WILL **** the car off Put the "excess plastic" back on and try it again. I bet it works fine
Old Feb 11, 2005 | 03:41 PM
It'll throw SES codes, but you can get those turned off.
Nayr
Mar 3, 2023 08:34 PM
AtlasXVIII
Aug 24, 2015 11:41 PM
detroitmuscle
Jul 31, 2015 04:21 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
