View Full Version : Drag Racing Technique
Pages :
10
11
12
13
14]
15
16
17
18
19
- Spohn Torque Arm Q?
- Woohoo! Changed out 700R4/10 bolt for built TH350/9" ... questions inside
- how do you guys get out of the hole?
- New times this weekend!
- What do stock Lightnings run?
- Busted 11s first time out
- Anyone using Goodyear radial drag slicks?
- Even Worse Times
- New draglight XPs anybody running them
- Super high stall on the street
- TERRIBLE track times!!!
- removing air filter?
- Who plans to enter the CZ28.com Nationals' Quick16 race??
- Hungarian 'Dragway' - Weekend, LONG
- 1.300 60ft on stock 10 bolt & suspension???
- Shifting/Launching tips wanted!
- Hotcam and street tires=12's?
- New Best
- 1st time at the track tonight and.....
- What Can I expect with this setup
- Need opinions on my next move!
- Calling All the Big Dogs
- Has anyone fit a 29x11.5x15 on their 4th gen?
- ran my 3.4
- Gearing Q's
- New style bmr ds loop
- The lightest 5 star rim???
- Q for Xtreme Torque Arm owners
- race!
- 15x10 Pro Stars
- how much heat do ET streets need?
- Boxed or tubular SFCs?
- Need traction advice!!
- anyone run 3.5" wheel with 1" BS on the front?
- Help me Run better them 14.1 in my LS1
- 13.2@105 New Best
- 15x10 wheels + 28x12.5 ET streets, which BS ?
- Drag Racing Clips...
- Line Lock users inside...
- New Best ET For The Official Z28.COM "Bottle Only" Car!!!
- Perfect 0.500 R/T
- street night muffled only
- 15.0@96 vs 14.3@96 Question
- Manual Brakes ???
- Wheels up Launch!!!!
- new tires-best place to buy?
- Thunder racing shootout for those that don't agree with the ls1tech rules.
- Drilling Front Struts
- ls1 swap suckin' at the strip
- These Nitto 555Rs arent hooking like i expected!
- Question on my 1/4 times?
- Drag Racing Videos
- Beefed up 10 bolt+M6+Street tires=?
- Line loc
- Question about light weight battery..
- What PSI in Bfg's??
- LS1/LT1 Racing Series - Opinions/Input PLEASE
- Ideas for skinnies with C5 brake conversion?
- prostar fronts ?
- Converting Rear Ends to my car
- First time at the drag
- To add to the "race tire fitment database"
- 60 foot times
- Has anyone ran this size of ET Street on their car?
- Ran a new best
- Short belt
- tire pressure
- Going to track this weekeng/ street tires psi?
- DR question
- lakewood traction bars
- Tire Question Nittos, ET Streets or...
- Safe to go Tubeless with MT ET Streets?
- What ET to expect with a 116 MPH trap?
- 115.5 mph + 3582 race weight =12.70 (I need driving lessons)
- How do you guys launch your M6?
- URGENT: Need help with bad wheel hop!
- Finally made it out to the strip
- First time at the track with my new car
- 9.60 @ 141.52 run at Bowling Green video is up on BMR
- 94 LT1 S-10, A4, hot programming 1/8 times?
- elevation formula?
- New times w/cam!!!!
- Michigan and nearby Drag racers LOOK!
- Wtf....
- Greg Moser killed in plane crash
- Atco Raceways Quick 8 Pics and Results !! Enjoy !!
- What are some good point to hit in an Informative Speach on Drag Racing?
- calling everyone with HAL/QA1s
- New Best !
- subframe con.s or 8. cage?
- fastest times youve run w/no cage or subframe conn.s?
- What pressure are you running with your Nitto tires?
- rear susp. setup for low 12's car
- Fastest reaction time.
- What's the biggest solid roller w/auto and what converter?
- New times on gas !!!
- 29 10.5w tires...gulp gonna try
- anyone ever brake a trans bellhousing before (A4) while launching?
- What kind of CAM should i get?
- rpm's crossing the traps 3.42 vs 3.73 gear
- swapped 600 for 750 ... now slower?
- Low 12's achieved N/A without LT1 motor mods. (post track report)
- Best ETīs on a LT1 3r Gen???
- whats the best 60 u pulled with a stock TA ?
- 9.60 @ 141.52mph! not too shabby ;)
- New line lock gp
- WOW! Close call to 'Running the Retaining Barrier' yesterday! Spool and Slick INFO:
- ET Drag Users
- How many Carbed 4th Gens in here?
- My first time to the track with ET streets
- F Body Shocks & Suspension?
- Anyone Have A SPEC Rebuilt? Can It Be?
- anyone install Eibach Drag Launch kit?
- Torque Arm a good mod?
- Post your 60' times. I need help.
- passing emmisions with hooker lt?
- Ran a new best....but think I mighta taken a head gasket out in the process.....
- How much with exhaust and cai
- Lightweight racing seats??
- Change My Tires?
- Trying the BFG DR's Friday
- 1st time at the track ,ever
- where is my mph gonna be after a 100 shot ?
- 13's?????????(maybe)
- PA K-member update
- The beast will be at the track soon :-)
- Carb intakes?
- my 11.37 pass at the track..could someone please host vid
- First time going to track...
- 14.513 @ 97.81 @ 2200 feet.
- Fastest heads/cam stock bottom end LT1 times what are they?
- Removing front and back bumper supports on a T/A?
- improving my times
- best weather for racing??
- Yank ss 3600 too much???
- Best way to set up the rear with adjustable shocks...
- anyone here going to Bowling Green shootout next Saturday, May 31st
- Low 12's
- poor track results
- Anyone running the Baer Bump Steer Rod Ends...
- First times with car, watcha think?
- would 315 nittos hook on my setup?
- Sheesh! BFG DR's wear quick
- what posi unit would be best for a street/weekend strip car
- What Size Slicks
- Calling anyone who runs 28" slicks
- which compound ET drag do u run ?
- Ok, going to see what the 3.73's..
- I got 2 GT's
- What PSI for ET Streets?
- Tire pressure on slippery track ?
- 2.73 track times=Yuck,?'s
- How much does an E.T. street grow at the big end?
- 60 foot after roll bar
- Drag Race Fanatic
- need rear suggestions!
- Need some help on TH350 swap.
- Skinnies
- New Best STREET TIRE MPH and E.T. - Videos
- What are skinnies worth???
- New Best Time... Could Be Better
- where to buy a "seat to rollcage" brace ?
- North vs. South Shootout in Bowling Green next week, who'll be there??
- exhaust
- solid motor mounts - solid trans mount???
- I'm getting worried about my Spohn TA....should I be?
- what mods to fit 26x12.5x15 et streets?
- Shifting Problems ... Master Cylinder?
- Fastest LT1 List?
- american Iron Shootout II, Results and Pics !! Enjoy !!
- What's a good 60' Time
- Some kind of deperate attempt to get the best of both worlds
- New Best 60ft!!! Now I'm A Believer...
- Better Traction: 255/50/16 or 315/35/17 DR?
- Lighter wieght
- ARE: Fastest Stock Susp 4th-Gen Record 8.71@161.8!
- Is my car TOO free now??
- Terrible Times, what's wrong?
- To 12, or not to 12?
- Reloctated Battery Now have charging problems
- Spohn Tq Arm help needed.
- First time to the track (times inside)
- need suggestion on size of my next slicks...
- New converter got me 12's!
- help? first time to track w/ new setup
- 12 bolt or 9"
- Cooling off intake?
- Big Stalls...
- Nitto 555r
- Now the gloves are coming off!!!
- What gears to go with?
- ONLY been to the strip thrice with lt1... and this doesn't seem right... too fast?
- Alright guys, A track Virgin Here. What rpm do you 3000 Stall guys launch at?
- Should I go 4 link?
- LCA and 60foot times?
- Need some advice on track.
- Stock LT1 With N2O Goes 11.6s!!
- new times
- Thoughts on Koni Drag Shocks...
- 1/8th mile MPH's
- I want 13.50s!
- Proper way to Power Shift
- Another 12 sec LT1 bolt on car!
- M6 shift points?
- New best N/A
- Stay Away From Summit Racing!
- mt ET streets tread depth
- Ok, heres the deal...
- BBC in a 4th gen F-body? Can it be done?
- Strange Owners - 1kwk?
- need opinions on times
- How many people have gotten a .500 R/T?
- Draglite / Bear brake compatability
- Launching with nitto's and an A4
- so I somehow gained 2 tenths without doing anything...
- Tubes or No Tubes?
- How strong are 12 bolts and what are you running with yours?
- 10.5 ET drags on 8" wheels ?
- 60ft. times
- Anyone make a 8.5" 10 bolt for 4th gens?
- Paging Tnthub
- Does Anybody Else Have To Use A Catch Can For This Problem??
- Making ET Streets LESS sticky
- Is it possible to get 11s w/ $3500
- what to expect
- Budgent Drag Car
- New Best At MIR This Weekend
- First time braket racing,What do i need to know/do??
- Need opinions: Strange vs. Moser, 12 bolt vs. 9inch
- How fast on stock heads?
- LED Lights at the track
- Ok, Track locator is pretty much done
- Hitting the Traps w/4.10s
- lifting the front 2 on the line.... HP requirement
- Michigan and nearby racers - Milan rented Thursday May 8th
- Help Launching
- Skinny on skinnys
- ET List
- Just wanted to let you know...
- Paging tnthub
- For those in the 10's...Suspension mods?
- What weight reduction have you done that's different?
- got "owned" twice in one night
- confused with times on gtech
- Which rim size is better for performance? 16X8 or 17X8.5
- teach me suspension
- k-member - which one???
- Line Lock questions
- Atco Raceways Quick 8's !! Pics And More !!
- ET Street Size for 15" rims
