Spohn Torque Arm Q?
Old Jun 23, 2003 | 08:24 PM
97TA-WS6-Con's Avatar
Spohn Torque Arm Q?
I have just installed an adjustable TA and I'm having a vibration through my butt that I need some advise on.
Here is the problem. Starting at about 100 kmh and gently increasing in intensity as the speed increases I get a rythmic thumping through my butt. The DS has been double checked for balancing. I also got the rear wheels balanced and that DID help, but the wheels are done right now. I was there when they did them.
I set the pinion angle to zero degrees.
So my question is, does the fact that the TA bolt just where the seats are cause increased vibration that otherwise I did not notice before?
Old Jun 23, 2003 | 08:50 PM
RUFFIDLNZ's Avatar
I didnt notice any difference in mine when I installed it.
Old Jun 23, 2003 | 11:34 PM
OBE1 95Z28's Avatar
The Spohn torque arm couples your drive train to the frame so more vibration and noise will be transferred into the interior. Any time you eliminate a rubber bushing your adding noise and vibration. You say you had your stock drivesahft balance checked...I believe the stock piece just resonates at around 70 mph; swap in an aluminum driveshaft (hopefully you can borrow one from a buddy) and see if the vibration is reduced.
Old Jun 24, 2003 | 11:31 AM
Z-RATED94's Avatar
Mines the same way. It's set at -1 degree. On the highway I found that the little vibration I have levels out at 72 MPH. I think it's one of those things I'm just going to have to live with.
Is it me our does your car seem to stop with a little less nose dive and corner better too?
Old Jun 24, 2003 | 01:57 PM
rskrause's Avatar
Moderator
If you have the spherical rod ends, you can expect a LOT of vibration. The poly bushings will also transmit some additional vibration.
Rich Krause
Old Jun 24, 2003 | 11:45 PM
Thanks guys.
I have the poly bushing. Also, the DS is a custom made 3 inch steel. oI sold the LS1DS. That would break when the stickies go on
I think I'll adjust it to -1 degree and see if that helps.
Z-rated: I'mafraid i did not notice any differance.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
