Need traction advice!!
Old Jun 16, 2003 | 03:05 PM
MARSTAUT's Avatar
With the mods I have and a 150 shot I am having very pour traction on my street tires. I have 18x10.5" rims in the rear and was thinking about getting the nitto drag radials (NT-555R) size 305-45-18, but these are a taller tire. I run the NT-555, 285-35-18's now. would this tire give me enough bite?
Old Jun 17, 2003 | 02:02 AM
AL SS590 M6's Avatar
Moderator
Re: Need traction advice!!
They will be taller. But enough bite for a 150 shot don't know.
I would add some LCA relocation brackets. Drop the LCAs to the middle hole. They might help you out.
Old Jun 17, 2003 | 03:58 PM
MARSTAUT's Avatar
I have the relocation brackets and BMR LCA's on the lowest hole, would the middle hole work better?
Old Jun 17, 2003 | 04:16 PM
RacinLT1's Avatar
the middle hole wont shock the tire as hard.
Plus the fact that 18" tires arent meant to hook up bolt on power levels in drag racing,let alone another 150 hit of nitrous.
You can try the nitto's,but i doubt you will get any 18" tire to hook when the nitrous is on.
Old Jun 17, 2003 | 06:29 PM
MARSTAUT's Avatar
thats what I needed to know, I'm just going to have to look around for some 16's with some drag radials. Someone told me you could get 15's on if you grind down the caliper, any truth to that?
Old Jun 17, 2003 | 06:35 PM
RacinLT1's Avatar
Yes if you grind on the caliper enough,you can get 15's on the back.
The LS1's take more grinding then the LT1's.
Old Jun 17, 2003 | 11:19 PM
Moderator
You could go big bucks and get some 15" Bogarts. They fit with no grinding or spacers.
Old Jun 19, 2003 | 11:16 AM
TedH's Avatar
150 shot? Et Streets, 15" rims, heat them up good on a sticky track and call triple A when you break the rear end.
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
