how do you guys get out of the hole?
Old Jun 22, 2003 | 08:40 PM
muraoka's Avatar
i leave at 3000 if i don't spin alittle (about 2-3 rotations) it bogs. stock 10 bolt so i'm afaid to leave any higher.
heres a couple passes
1.858 60 ft. 7.689 1/8 11.804 1/4 120.93 mph
1.849 60 ft 7.689 1/8 11.742 1/4 116.87 mph(lifted to avoid break out)
i get consistant 120 mph but the car just seams slow for that mph.
car is an m6, 4.10, on et streets.
thanks for any help,
matt
Old Jun 25, 2003 | 11:09 AM
Lynxis's Avatar
get some good tires and floor it
a4
Old Jun 25, 2003 | 11:13 AM
Grover's Avatar
a4
He's already running ET Streets.
The only thing you can do is put a 12 bolt or 9" under the car and then leave at 5,000 +. Those are some very impressive times for a M6 with the 10 bolt.
Old Jun 26, 2003 | 02:16 PM
TedH's Avatar
Start saving for a 12 bolt so you can do a proper clutch dump.
Old Jun 26, 2003 | 02:58 PM
kazman's Avatar
My car's happy spot was dumping from 3750, 14lbs in the drag radials. Lower rpm would bog, more rpm would spin. Note: your 10 bolt will not last dumping the clutch.
Old Jun 26, 2003 | 05:51 PM
muraoka's Avatar
thanks for all your help. i figured a rearend is in order but i just ordered an 8 pt bar ($109.00) from sw race car to stay legal any ways i'll run once more and see if i can get a better 60 ft i'll try opening the exhaust and i leaned out my nitrous and added a bottle heater this time preassure should be up not at 600lbs. can't wait to see how it'll run this time.
thanks matt
Old Jun 29, 2003 | 02:54 AM
96LT14u2Nv's Avatar
jesus! that is on the stock 10 bolt?!?!?!?! u are a BRAVE soul!!!!
i would not go any higher than 3,000 on that rear (i wouldnt do anything at all with it) but, u need to save for a 9" and dump the clutch at 5,000 or so RPM. that is the best i had tried when my car was a 6 speed.
Old Jun 29, 2003 | 08:50 AM
kevkop94TA's Avatar
Thumbs up
Those are pretty damn impressive for a stock 10 bolt M6 IMO. Save up for a 12 bolt or 9in. and You'll have the 60's and your et down where they should be.
Sounds like a pretty damn nice car.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Victor Lamb
Aug 26, 2017 02:52 PM
edman
Jan 22, 2015 02:45 PM
owen66
Nov 30, 2014 04:21 PM
Red97LT1
Aug 7, 2002 05:45 PM
