Hitting the Traps w/4.10s
Old May 4, 2003 | 09:45 PM
Silver02Z's Avatar
Ok, this is the setup.
4.10s
M6
16-inch tires with 245/45 drag radials
If anyone is running the combo; what RPM are you at when you hit the traps?
What kind of gains did you see when you went to the 4.10s. I tried doing a search, but couldn’t find this specific answer.
Thanks!
Old May 5, 2003 | 04:55 AM
rskrause's Avatar
Moderator
Re: Hitting the Traps w/4.10s
4.10s
M6
Thanks!
How much hp are you making? How high do you want to rev it?
A 16" radial is ~26" tall and won't grow much at speed. For that tire with 4.10's, 5,800rpm is ~109mph, 6,000 is ~113mph.
Rich Krause
Old May 5, 2003 | 08:29 AM
Silver02Z's Avatar
This is on a stock motor, stock manifolds with cats. I was just concerned about hitting the limiter in 4th before hitting the traps.
Old May 5, 2003 | 02:49 PM
rskrause's Avatar
Moderator
I don't see many stock LT1's, but unless they run faster than ~109mph you won't have a problem.
Rich Krause
Old May 7, 2003 | 11:27 PM
RUFFIDLNZ's Avatar
You wont have any problems with the 4.10s.
Glenn
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SergheiS
Sep 29, 2015 08:56 PM
alliance12364
Sep 23, 2015 12:40 PM
