Line Lock questions
Old Apr 29, 2003 | 08:27 PM
ElkyRacer's Avatar
Line Lock questions
I just put a Moroso line lock on my car. It seems to work fine. Put it between the master cylinder and the proportioning valve. So I pump the brakes, flip the switch, and let off the brake pedal. It locks the front brakes. I do my burnout and flip the switch off, but the front brakes dont release. I have to stab the brake pedal to release them. Is this normal? Thats going to be kinda tricky rolling out of the burnout. I didnt think I had it backwards. Just wondering how all of your line locks work.
Thanks.
Kyle
Old Apr 29, 2003 | 08:39 PM
Stephen 87 IROC's Avatar
It needs to be after the proportioning (combination) valve to pass a tech inspection. That could be why it's not working properly.
Old Apr 29, 2003 | 09:09 PM
ElkyRacer's Avatar
Hum, I dont see how that could work out. All of SLP and Thunder Racing kits go between, seeing its a ABS car. I thought they had it that way so that the ABS control wouldnt freak out. One of my friends has the SLP kit (basicly the same except pre bent lines as I bent my own) and his doesnt do this.
Thanks for your imput!
Kyle
Old Apr 30, 2003 | 07:22 AM
dougg01's Avatar
My hurst is between the mc and the ABS controller using thunder racing's line kit. Works liek a champ. press brake, switch, release switch, stab brake again, press switch....burnout.....release....
Maybe your solenoid has a problem...?
Old Apr 30, 2003 | 07:49 AM
ElkyRacer's Avatar
I was looking at Brady's website last night, and saw he has the same unit I do. He had his plumbed in opposite as I do. That might be it. Ill give that a try and see.
Kyle
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Feffman
Oct 9, 2015 05:42 AM
capebuf
Jan 13, 2015 07:22 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
