Launching with nitto's and an A4
Old May 9, 2003 | 07:01 PM
z28s's Avatar
Question Launching with nitto's and an A4
Just wanted to ask how you guys using Nitto's launch your car's at the track.....i have an A4...my best 60ft is a 1.9, also what air pressure do you use...i have my nitto's on a set of salad shooters (245/50/16) thanks in advance
Old May 9, 2003 | 11:02 PM
cooker93redz's Avatar
can't really answer your question but wondering what track you go to?
I've only been to St. Thomas Dragway near london and it's terrible
Old May 10, 2003 | 02:01 AM
rock1501's Avatar
I get high 1.6`s at StThomas with my Et streets and 1.7`s with my 315 Nittos.
Are you going to the F-body-Stang shootout at TMP Today
Old May 10, 2003 | 01:13 PM
z28s's Avatar
i usually go to St.thomas dragway as well....
Old May 10, 2003 | 05:04 PM
maybe it's just cause i've only been twice and only to street legal nights and they probably don't really prep the track...
and no i had to work today
Old May 10, 2003 | 07:10 PM
97silverz28's Avatar
I'm using the same exact combo as you for the track. Your times are a little better than mine. The track I go too is also BAD.
Old May 12, 2003 | 03:48 PM
offaxis's Avatar
Re: Launching with nitto's and an A4
I used to run size nitto on my car with a vig 3200. IT was an awsome combo.I would run the tires at 18 PSI and I would go around the water box then do along burnout. I would wait till I saw smoke then i would count to 7-10 seconds. You really have to heat them up good to get them to really stiick. then go up to the line and foot stall to say 1500 rpm When the light goes green I get into the gas say half throttle or so I dont floor it for like the first foot then I floor it after i have traction. I would adjust when i floor the gas depending on track prep. This technique averaged me 1.60-1.65 60 fts on stock suspension withthe front swaybar removed. Hope that helps
Jeremy
Old May 12, 2003 | 07:19 PM
transamtom's Avatar
Hows it going? I think you did everything right at St Thomas.
The problem getting it to hook is more related to weight transfer or the lack of it in your case.
I think the lowering springs are hurting you.
Even when you bolted Romans ET Streets on your 60fts did not improve by much.
Lowering springs are great for the FWD crowd as you don't want weight transfer,but we need that weight to get the tires to plant.
Old May 13, 2003 | 02:31 AM
rock1501's Avatar
I lower my Nittos to 16-19 psi depending on how sticky the track is.
Never goto street legal Friday nights and expect to get traction.
The best traction you will get in this area is Grandbend or Toronto Motorsports Park on a points day
Old May 13, 2003 | 11:42 AM
transamtom's Avatar
Dave are you going to the TFBM event at the end of the month?
I think I may go Bracket racing at TMSP on the 25th as well.
Dave, Your absolutely right about the Friday nights,I went twice,never again.
Old May 13, 2003 | 11:48 AM
rock1501's Avatar
Ya I will goto both.I was thinking about going this weekend too but I think I will stay home and clean the carpet in my car.It got real muddy from last weekend`s F-body Stang shootout.
Lots of "Mudstains"
The TFBM event is easy money for us auto guys
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
mrwz28
Jul 8, 2015 09:11 PM
