Spohn Tq Arm help needed.
Old May 17, 2003 | 05:28 PM
my96z's Avatar
I broke my stock torgue arm and bought a spohn unit. Now I have been adjusting this thing from -8 to -2 and it still hooks like crap. The stocker was way better. Do I have the formula backwards?
driveshaft angle - pinion angle= total pinion angle?
Is that correct? Should the pinion point more towards the ground or up toward the car?
thanks,
Jeff
Old May 17, 2003 | 06:11 PM
The driveshaft and the pinion shaft should form a "V" pointing down at the ground. That way, when the pinion shaft noses up under load, it will "straighten out" the V. I run -3deg.
Old May 18, 2003 | 09:55 PM
nd4spd200's Avatar
screw the formula, just put the gauge on the pinion shaft and point it 3 deg towards the ground, this is how i set mine i pull 1.5 short times and pull the wheels 6-8 in, i have a guage just for pinion angle, i forget who makes it.... adjust this setting at ride leval... so all four wheels on the ground.....
Old May 18, 2003 | 10:10 PM
my96z's Avatar
Thanks man, I am going to try that. Maybe its cause my nittos are about 4 yrs old... But I was expecting way more than that.. Best I got is a 2.1 and I have just about all you can do to a rear suspension other than Hals and airbags.
Jeff
Old May 18, 2003 | 10:54 PM
AL SS590 M6's Avatar
Moderator
Originally posted by my96z
Maybe its cause my nittos are about 4 yrs old... But I was expecting way more than that.. Jeff
Yep 4 year old Nittos??? You'd probably be better off on new street tires My Nittos were at the begining of their 3rd year and wouldn't hook for crap.
I'd get some new DRs or Street slicks then start cursing the torque arm.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
