tire pressure
Old Jun 10, 2003 | 08:01 AM
CHRISCAMARO's Avatar
tire pressure
what is the best tire pressure you guys use at the races for your stock tires on camaro 16" (P245 ZR50)
thanks
Old Jun 10, 2003 | 09:11 AM
Redbird's Avatar
Lightbulb Well the BEST/ONLY way is to...
...Find a fresh asphalted stretch of roadway and do some 'tire testing'. This is true for ANY type of tire, street or drag.
Maybe start out around 30#'s of air in each. Do a short burnout. Get out and look at the contact patch. Next go down or up depending on the results/looks of the contact patch.
Key:
1) A thin patch left on the pavement means TOO much air, reduce pressure accordingly.
2) 2 dark lines for each tire means TOO little air pressure, increase pressure.
You are after the full contact patch from the tire. You might even take along a measuring tool to measure tire surface area AND tire contact patch area on the pavement. You will be looking to get as wide and dark of a contact patch as possible.
Good Luck!
Old Jun 10, 2003 | 03:21 PM
HungryT/A's Avatar
Redbird,
Thanks for your reply and your other post as well. Testing different pressures on a strech of empty road is definiatley a good idea!
later,
Old Jun 10, 2003 | 06:35 PM
street demon2k3's Avatar
on my BFG's i use around 25-28 psi and they hook up well. considering that i have almost no tires left they perform well with that pressure.
RichJ
Sep 14, 2002 09:37 AM
Frank95z
Sep 10, 2002 08:30 PM
97bowtie
Aug 25, 2002 11:00 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
