WOW! Close call to 'Running the Retaining Barrier' yesterday! Spool and Slick INFO:
Old Jun 2, 2003 | 08:55 AM
Redbird's Avatar
Unhappy WOW! Close call to 'Running the Retaining Barrier' yesterday! Spool and Slick INFO:
Two things happend here that I NEVER expected.
1) Redtird left the line and immediately headed for the outside wall. A FAIRLY HARD right if you will. Stayed in it and saved it, completed high 11 second run.
WHY (I think): POOR MANS SPOOL! Passenger side tire in sumpin' slippery, both front tires off the ground about 6" for a bit. Driver side tire hooked and sent the car headed for a 'Cement Cruise'.
I'm pretty sure this is what happens now when both tires drive (spool) ALL the time.
2) Slick rotation. I NOW remember that it takes a few runs to get the slicks reacculmated to a different rotation. First two runs were a tenth off of RB's normal low 1.5X times. By the third run she was leavin' hard and straight, again!
ALSO... Bryan Herter solved my '94 no shift 1-2 problem, THANKS!
He is at PCMFORLESS.
HInk (seeing light at the end of the tunnel, NOW)
Old Jun 2, 2003 | 02:05 PM
chevyguy3's Avatar
i had a similar incident saturday night. had already put the car on the bumper and smashed a lot of stuff earlier in the night so i was very alert on the line at least. came up for a nitrous pass later in the night, dumped the transbrake on the bottle and the car jumped straight for the right wall. was in the throttle maybe half a second and ended up all the way off the concrete. turned out somebody a couple cars ahead of me left coolant on the line that nobody noticed
Old Jun 2, 2003 | 04:59 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Thumbs up
HInk,
good save!!!! you don't want to muck the shiny red paint on yuor ride!
that must've sent your heart a pounding!
Old Jun 2, 2003 | 10:02 PM
AutoRoc's Avatar
ytuikuy
Good Save Kevin!
What's the reccomended cure for the problem though? SHock settings, air bag tuning? Bigger sway bar?
Old Jun 3, 2003 | 09:10 AM
Redbird's Avatar
Arrow Thanx boyz...
Denny... I am gonna do some 'fixes', but I figure the ROOT cause was something the passenger side tire got into and spun. Being a spool now, the driver side tire kept driving, pivoting the car a bit on the spinning right tire. Just need to look at the line a bit better, before staging.
Next run the car left hard and true. I did take some air out of the right airbag but I don't really figure that was the problem, but...
needless to say, the airbag WILL remain at 17 psi from now on!
HInk
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
mr28
Apr 20, 2016 05:44 PM
squarehead
Jan 15, 2015 07:02 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
