Skinny on skinnys
Old May 2, 2003 | 07:56 AM
BBB's Avatar
BBB
Skinny on skinnys
How much ET drop can I expect in going from a stock 4th gen 16x8 (about 50 lbs) to a skinny setup?
BBB
Old May 2, 2003 | 08:00 AM
TedH's Avatar
The very general rule of thumb is a 100 pound drop equates to a drop of 1/10 in the quarter mile. This will vary greatly based on many factors.
Old May 2, 2003 | 08:10 AM
MattSLONOMO's Avatar
the advantage here is not only weight..but unsprung weight and
much less rolling resistance..
I gained 2/10's when my T/A was a 12 flat car..
going to the skinny's..
also..look to the P165's that have the 44psi max rating vs the
ones rated 35 psi...they have less resistance too..and you don't
have to worrry about breaking belts by over-inflation..
Matt
Old May 3, 2003 | 11:48 AM
BBB's Avatar
BBB
Wazzzup Matt? How is the car doing? Hey and I haven't asked for a while but how is your son doing (run Forest run)?
The reason I asked about skinnys is that last year I experienced a .15 drop in ET when I went from my 17x9.5 combo to stock 16x8 on the front. On the rear I dropped another .15 from a similar swap and another large fraction because the 16x8s were a soft compound tire allowing a larger rpm launch.
I understand the mathmatics of unsprung weight, reduced weight of any type and rolling resistance. Also of major concern is rotational mass. If guys are spending a ton on lightweight valvespring retainers and driveshafts without lightening wheels then they are idiots.
I am trying to see where my money is going to be better spent. I can get a good skinny setup or a really cool light weight hood for about the same bucks. I am trying to figure out what will give me the best drop in times. The weight reduction on the car will be about the same, but what I do not know is how much the reduced rotational mass will be an advantage (engine spooling up quicker) over reduced weight over the nose (enhanced weight transfer and traction).
Wow I hadn't thought about it in those exact terms before but this if a little more complex than I first thought.
Oh just food for thought my car is dynoing 343/356 and I have done some recent up grades that should be bumping that number by about 15/15.
BBB
Old May 3, 2003 | 11:58 AM
TedH's Avatar
Rollout is also a factor. larger diameter tire will provide additional rollout. So, depending on how you stage and how you launch you can pick up some ET by breaking the beams differently. I know that moving from a 26" to 28" front made it much easier on the tree in my car.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
jwade88
Jun 14, 2015 09:38 PM
KillerTA
Wheels and Tires
May 31, 2015 12:20 PM
