Best ETīs on a LT1 3r Gen???
Yesterday, I take the car to the track and my time at the 1/4 mile was really bad.. ŋ15.8 sec 1/4 mile?
Is this normal? the day was hot as hell (100°f) I know 3rd gen is too heavy, but 15.8????
I try some Ice over the intake, even take off the left head ligths for fresh air, but 15.8????
any of you guys with Lt1 3rd gens,?
. Is this normal? the day was hot as hell (100°f) I know 3rd gen is too heavy, but 15.8????
There is a guy on our board www.kyfbodies.org that has an LT1 in his 3rd gen and if I am not mistaken he was running mid to low 13s if not 12s with his motor. He has N20 on it too and was running low 12s and high 11s.
From: Teeter-tottering between Brilliance and Insanity
Re: Best ETīs on a LT1 3r Gen???
uiliu
Yeah a 15.80?? An LT1 thirdgen should run just as well as an lt1 fourth gen. Same weight, same rear suspension, same transmissions, gear ratios, etc...
Figure about 13.80-14.20 all stock. 100 mph
Maybe mid low 13's with a lot of bolt on performance parts...103-106 mph roughly.
I would hook up a scanner or LT1 Edit and see what's happening overall.
yes a 305 tpi thirdgen runs aout mid 15's at they make 195-215 hp... Yours should make about 260-290 and ET/MPH accordingly.
What mph did you get at the track in the 1/4 mile? That's a better indication of power than ET. I've seen 12 second capeable cars run 15's since the driver was not up to par with the car. I wish you luck man.
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 11:32 AM
