rear susp. setup for low 12's car
Old Jun 3, 2003 | 10:27 PM
IrocSS85's Avatar
my Iroc now launch's real hard, and the tires are contacting the qrtr panel lip on the inside. so its squating pretty hard. what setup do you guys use, as in, brand shocks, airbags?, springs, and list your 60's w/that please. I ran a 1.74 sixty last time, and I know if will get into the 1.6x on a better run. I have stock susp. so far, except the panhard bar. I was thinking drag shocks from summit, airbags, and box my control arms. what do you guys think?
chris
Old Jun 4, 2003 | 07:13 AM
rje's Avatar
rje
I have the eibach drag launch kit with QA1 12 way adj struts set on the softest setting up front. In the rear I have competition engineering 3 way adj shocks set on 50/50, along with boxed LCA's, tubular panhard rod, BMR Trac-pak with 3 degs negative pinion angle, Alston SFC's, and BMR drag anti-roll bar. With this setup and a race weight of 3440, and I weight 230lbs, with a nothing special 355 LT1 I've ran the #'s in my sig. Hope this helps.
Randy
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
Jon657
Jul 19, 2002 07:51 PM
Absolute Z28
Jul 19, 2002 02:21 PM
