View Full Version : Drag Racing Technique
Pages :
10
11
12]
13
14
15
16
17
18
19
- CRCDUDE is the man!!!!!
- 1/4 mile time kinda
- Line lock on rear brakes
- custom roll bar. wolfe guys in here
- 2004 NHRA Rule change?
- Doh
- Beat a 97 LT1-Whoopty Doo
- pointers for a rookie at the track
- Auto vs Manual, which is faster in a all out race car.
- 12.97 LS1 video/times
- I did it!!!
- 11/2 Rockingham, NC track meet
- Thoughts on how 3.73's will affect my ET/MPH? Oh, and new best :)
- 1/8 mile runs!!!
- New Best! 11.13 @123mph
- Who knows MOSER 12 Bolts?
- new best 1/4 times
- 1st time at 1/4 mile track 13.2 101.9
- Going tubless. Do I need valvestems?
- Boxed or tubular LCA's?
- What front springs with the Hal's?
- Nitto tires
- Possible 12s?
- Quickest 4L60E equipped F Body
- come in if you're running weld wheels
- The quest for 10's with the stock LT1 has ended
- Stock Stall and Et Streets
- Backspacing
- 13.3 @ 103.8
- New track times
- 3000 stall too much for stock setup?
- wheelie pix??????
- 18 bfg drs
- Cam suggestions?
- ran my car this weekend...
- just bought a S&W roll bar
- Another What will I run thread (LS1)
- Went to the track.........
- burnouts
- which drag wheels?
- Bleach on crappy slicks?
- First time out new set up 11.02@124.9
- New Best 12.000@113mph
- first track times
- Skinnies and C5 Front Brakes
- 18" hurt 1/4 mile, how much?
- 8.96 @155
- The Quest for 9's continues
- The stock shortblock LS1 record has been pushed even further
- What gives the best ET.. TH400 or Powerglide...
- New LT1 FI Record!
- First 1/4 times driving LS1 M6....
- What rims and tire choice for my car?
- 16 in back 18 in front?
- new 1/8 mile track times
- 12.3's w/ stock heads & 230/236 cam
- Gauges?
- Proper Burnout Procedure A4
- Question about weight reduction
- INVITE,Calling All Central Texas!!!!
- want faster 1/8 et but problem
- QA1 drag shock question/
- best shocks for drag?????
- New best, but just barely
- how do you drive your m6?
- Heads up on running Nittos (air pressure)
- What do you think of these times?
- Doh!!!
- Orlando Updated 10/14/03 Updated!! Finals-Included
- Best price on Weld Draglite's?
- NHRA legal bulkhead
- hey all can U post pics of your cars?
- 11.33 on G70-14 bias plys!
- Airbag Sensor Under Center Counsel
- what kind of shocks?
- Taner Bonsnali Wheelie -vid-
- BFG Drag RAdials Comp T/A
- Ply mix,oxygen sensors
- 14.68@100.7 whats wrong?
- First time to the track.
- Bracket Racing Questions
- Suspension power loss?
- New best (11.48) .. video inside
- went to englishtown yesterday
- I need help pulling better than 1.60 60ft
- Just a little quicker new best 10.608
- Really fked up night at the track?!?
- Lug Nuts
- Looking to hit 12s with just bolt-ons
- just wanna make sure.. LT1-LS1
- What should I expect??
- Looking For People That Have Gone To Manual Brakes In A 4th Gen
- new best @ Gateway, GIR
- Whats the cutoff...
- who has the best 60' on the stock convertor?
- Adding Nitto's and FTRA
- New Best...Mostly Stock
- Low 12s With Stock Longblock???
- Congrats to znines, fastest and quickest LT1 9.006@159mph
- OBD1 or OBD2?
- New track times with my 224/230
- Going to the track for the first time...Any suggestions?
- getting closer...new best
- New best also at the EFA shootout
- New best 12.22@110mph
- 383 hot cam times
- expected new 1/4 times?
- Launch help with nittos.(m6 guys)
- what 1/4 time can i expect?
- Another 10 Bolt goes bye bye!!! And the quest for 11's is over!!
- 03 Cobra vs. 99 Z28 Supercharged?
- 9.71 @ 140.54 mph :) 1.29 60'
- New Bests at EFA shootout...very surprised at results
- should I be hitting 4th gear in the 1/4 mile?
- Car is still puzzling...
- shift at what RPM's?
- TR224/224 .563/.564 111.6lsa
- Need Help
- New best, smoked clutch
- Made a new best!
- How does this time sound...
- what are they using ???
- Harwood fiberglass hood
- what hooks better: bald or good street tires
- New 1/8th Mile times with HOT cam
- What kind of helmet to get
- Race Seat Tech ?
- East Coast People
- changing gears
- Adjustable Shocks for Racing/Street
- What is your definition of "Street Trim"
- First time 1/4mi
- new times shouldn't they be better
- factory rear
- Best OEM wheel
- V6 front springs
- Does anyone drag with stock tires and rims?
- bfg drag radial hooks better than et street
- Fastest cars on 17inch wheels???
- MPH gain after 1/8th?
- What kind of helmet do I need?
- RTs don't hurt your ETs??!
- Need budget traction ideas
- any traction results from moving battery to the trunk?
- 11.38@ 122 mph
- New track times...need launching tips for M6
- What drag wheels fit without modification?
- Could a fat sway bar hurt my hook?
- what is my problem
- Drag racing 101 help
- guess my times...
- good decision?
- advice with new track job?
- 2.1 60'... Help!
- Th400 vs Th350
- boxing LCA should I go all the way around or just bottom
- will my axle handle dr's?
- comp 306 cam and 60'
- 1996 SS=13.6 stock
- New best tonight, any opinions?
- How much do our cars weigh stock?
- widest 28-29 inch tire??
- icing intake?
- Would new rear sway bar help
- need 15" tire suggestions for street use
- anyone heard of ZOOM gears ?
- I have an idea for the rear sway bar see what you think
- Roll bar question??
- Hey threadedtire, we got ya :) almost made it to the 10 sec motor club
- Can't get better than 2.06 60' with slicks. Help!
- New Best!
- new times with 230/236 cam!!!!
- comp. eng anti hop bars
- new racing k-member
- Rear drag shocks...
- went to the track last night!
- 60' ft times?
- 1/8 th times ?
- Need some help with wheel/slick sizes
- New times inside
- Springs and ET
- I can't drive!!
- what a rip off!
- torque arm pinion angle setting...
- Racing Requlations.....
- what do u all think of this setup?
- Fuel Regulator
- New Setup, need advice...
- Launching in 2nd gear
- Pulled a pretty decent time 1/8th
- What do you think I'll run??
- chasing those pesky 9's
- 275/50 or 275/60/15?
- Why does New Track mean bad times?
- 255/50-16 or 295/35-18 BFG drag radials?
- 60 Down 1/4 Up
- went from 13.8 to 14.3
- Tanners goin down!!!
- Hey TANER, We got ya, 11.22 @ 118
- pullin the front wheel on a 1.9 60' .. pic and vid inside ;)
- How much do your skinnies weigh?
- why did my street tires out do my et streets?
- Best gears for low end speed for street
- to race or not to?
- 1/4 mile results on 95 Formula... tried for 13's :(
- Nittos or BFGs?
- Relocating battery - Optima dry cell
- 1/8th mile times
- SC/NC/GA Fbody guys in here...
- Good air = new best 10.611 n/a
- Body Modifications to run 26x11.5x16 ETs?
- What do you guys think???
- Best Air for Racing
- what 1/4 times can i get?
- Story time
- 1994 Z28 - 396 4-bolt LT1 - Solid Roller, AFRs...- 8.62 @ 165 - 1.33 60'
- what is a good rearend gears for 1/4 mile
- Need a fast answer
- Anyone change gears and gain MPH?
- Slick Recommendation...
- what gear to start in???? 3 or D?????
- hal/qa1 vs. kyb
- What can I expect?
- Removing or moding the PHB "brace"
- Will I bog with 28 inch tires?
- Hoosier QTP vs. MT ET Street
- New best (see sig)
- 'Circle track' rims on drag strip?
- What To do??? Want better 60's
- any tips on launching at a pro tree?
- New Timeslip
- If you want lower ET and better 60' look in side
- how to launch with a auto at the track
- 1.76 60' and 8.25 1/8...bolt-ons only
- First time at the track with the Z
- why do I suck at 60 fts?
- ARE In Car Video 8.60's
- Are Video 8.54@167.33 !!
- Good news on the ttop rumor
- Ford SHO's???? What do they run?
- Gear Vendors Overdrive
- 29.5x10.5 ET Drags
- What are your 60ft times?
- What Rubber should I get for my stock rear in my M6? I've searched the archives
- ET Streets - Can't get them to hook!!!
- Anyone using spohn's driveshaft?
- 2nd trip to the track!!!
- 1/4 mile time
- anyone here see any real gain when removing front swaybar
- Making this Camaro consistent
