View Full Version : Drag Racing Technique
Pages :
10
11
12
13
14
15
16]
17
18
19
- LS1 and LT1 K-Member Differences
- American Iron Shoot Out !!
- 26" or 28" front runners?
- question about shifting
- 28" tire, pinion angle, and adj LCA's. Q's inside.
- buying a 454, what tranny?
- What Driveshaft are you High HP guys running?
- What Should I Run?
- 18s???
- Anyone using Centerline Warriors?
- BMR k-member prob....
- cheap 15" rims to fit 4th gen f body
- 1/4 mile times? I'm confused.
- whats the best drag racing suspension parts to buy
- New Times!!!
- How much ET are QA1's worth?
- will i hook up?
- Driveshaft length for TH400/Moser 12
- Need some converter advise
- Needing some advice on front runner wheels
- Suspension for a better hook up.
- Spring Shootout, San Antonio, March 9th - CANCELED!
- Need a Posi recommendation...
- Qa1/hal Install Big Problems!!!
- Track prep?
- TH350/TH400 Guys !!! Converter help !
- 1/8th MPH???
- Need advice on rear end gears (4:11-5:38) Drag only
- Your best 60fts and what kind of tires?
- Anybody run 28x13.5 tires ?
- Factory Chassis Welds good?
- 13.8s? why
- Guys w/K-members Need Help ASAP!!!!
- Carpet
- 60 ft Improvement
- 17" ET streets
- drag tires???
- Motor plate mid plate?
- difficulty level in launching a LS1?
- Drive Shaft Loop
- NMCA March 14 - 16 Atlanta Dragway Commerce, GA, anyone looking to go and race??
- New car nearing completion
- Gear suggestion
- fastest start at the line...
- Custom Cage$$$
- Any Pics of sumped tanks
- Fule cell
- Is it true? M/T ET streets only have a 2 year shelf life???
- Just how weak is the stock rear end on 4th Gens?
- M/T ET Street tire size question????
- Rim screws?
- Help me decide what drag wheels and tires to get...
- 1st time running...Need some opinions
- Anyone else yank their swaybar?
- Can you repair a ET street?
- R1 Racing Seats Any Good??
- need a part# for this intake
- Stru tower brace and drag racing, yeah or nah?
- This Should Make Those Ford Boys Think Twice About Our Small C.I. Motors...
- Hoosier 28x10x16 slicks??
- Anyone seen/using one of these with their harness???
- What clutch to get? (already searched this topic)
- The qtr mi HP calculator???
- Anyone run a dragster?
- 4.10's in a bolt on LT1 car?????
- When in the 1/8 is roll cage needed?
- Launching with F1s
- Challenged For A Race...
- What Are Your Times And Speeds
- I Want To Be Faster
- Sweet!!
- Shock and Spring Setups
- Yanking front and rear sway bars??
- Ebiach Drag lauch kit users post '60 times please
- brake torqing
- which torque arm ?
- 10.14 run video is up! cool!
- Congrats to Bill Plummer!
- SPRING BREAK SHOOTOUT! - March 9th - TX
- lowered with good weight transfer?
- When does your season start?
- 2800 Vigilante-->3600 Yank
- Pinion Angle
- What rims and tires???
- TH350...Which dealer makes the best tranny?
- Will I Blow stock rear end with ET Drags IF....
- difference switching from 26x11.5x16 to 26x10.5x16 e.t. streets?
- Relocation LCA bracket question
- Best 60 ft with nittos?
- who has the fastest LT1(M6)
- traction
- Madman Questions
- lakewood traction lift bars...
- I am unclear on relocated LCA's
- Modifying stock torque arm???
- suspension question
- Camaro w/ Twin Turbo
- what #'s do you think ill be putting down
- Bilstein HD's for drag racing?
- How do you launch w/your 6-speed on slicks?
- ET vs MPH
- How to remove front bumper supports?
- Question abot ET streets
- Quick Question About Racing Seats/Harneses
- Best BONE STOCK LT1 A4 E.T.s......
- Drag wheels
- Convert a 4pt. to a 6pt. roll bar ??
- 12s with stock stall, is it possible?
- bigger sway bar in the back... really helpfull ???
- roll bar need help!!!!
- Suspension
- Any pics of race-type auto shifters in 4th gen?
- will these wheels work??
- new N/A times
- New Calculation of Reaction Time/NHRA
- long distance slicks ?
- Narrowed rear?????
- Times with Yank 3000
- Eastern F-Bodt Assn... nice thread LOL
- Where can I buy virgin Xylene or Toulene?
- New Best - Video
- 10.59@128.68, 1.43 60' - LS1 346ci 6-speed ALL MOTOR!
- Sub 11.99 rules?
- 17" ET Street
- Shield or blanket?
- Going to SLP day Need HELP!!
- Need Converter Suggestions
- Please comment on high stall converter on the street.
- shift point?
- New Bogart RT P1 series rim Gauging interest
- SBC in LT1 cars, What Did You Do For A Motor Plate
- What rpm wil i be at crossing the 1/4??
- Madman's Alternator Bracket
- any M6 guys use the line lock on the launch ?
- Preferred converter brand?
- What size ET Streets for my Salad shooters?
- 26"x11.5" ET Street vs 28"x12.5" ET Street
- help with new setup??
- Extreme rpm's!!!
- Hello 12's, nice to meet you FINALLY!!!!
- First Bogart Drag rim P2 production out for F-bodies!
- new best
- rear end gear question
- Quick Question???
- Yeesh, wish me luck for 12's again..
- I know a ton of ways to make an LS1 light, how bout an LT1?
- BF drags
- TH400 Questions
- Question on times...
- Burnout in Second Gear? First Gear?
- 4l60e??????
- A T S Performance in Columbia, SC?
- Hello
- looking for tips on ET accuracy
- Guys with aftermarket K member...
- what rear springs to run with a HAL/QA1 setup... and smore more Qs
- traction= lower or higher MPH??
- weight diff 700R4 - th400
- With ~$500, after STB/SFCs what next
- first time to track
- Nitto 555R Drag Radials Vs Road race tires ???
- Need track advice
- lakewood Lift bars
- suspension questions?
- Where to buy G-Tech Pro Competition?
- Light Weight Seats
- My car inthe April 2003 Chevy High Performance
- First time at the track w/ the WS6 :)
- Weight Reduction - Carpet
- Anyone running a "W" or "S" tire?
- Heads up at the East Coast Nats!!!
- Weight difference between a weld and a weld XP
- a tenth in the 8th ='s ? in the 1/4?
- Shelf life of DR's & slicks?
- good 60ft time for a 93z
- KYB AGX shocks?
- You Wont Believe What This Guy Is Claiming To Run With A Stock Z.....
- OK, Whos Got The Fastest Winter Beater??
- Help on picking Drag Radials for street?
- Bogarts are on!
- LT1 guys trapping ~115 got a ?
- Take A Guess At What My New E.T. Will Be....
- traction???????
- Gears and Times??
- Finally: Dyno numbers, but somethings not right
- Drag radials
- TA vs. MAC rear Girdle (For Drag)
- Sig Length
- 3200 to 3600 stall.
- spohn torque arm, pinion angle?
- Nitto extreme drags size
- First times with Hotcam
- Mission accomplished... N/A 11 second Bolt-On LT1!!!
- New Stockhead LT1 best
- Need help hooking with 4.10s and 17'' rims!!!
- Front skinnies
- need help on setting up hals?????
- front sway bar?
- Well...My first track times EVER!!!
- Replacing Heads
- NMCA EFI Quick 8 schedule finalized!
- PICS FROM SEASON FINAL QUICK 8's
- Funny car bodies for 2003
- Cooling pics
- Time Question
- Anti Roll Bar vs. Air Bag
- Power steering.....Can we just cap it up???
- best performance shift points
- best brand of gear for my 9"
- Nitto's did the trick
- Anyone running M&H Racemasters DOT Drag Tire??
- Congrats to Matt Slo No Mo
- Hot cam in, sticky tires needed but...
- 2003 Events/Racing
- Drag Tire Comparison Help Please
- M6 guys....what clutch.
- Does anyone have actual results from a gear change?
- Installing Moser 9" in about a week..Qs?
- What can I do..
- Question about differential types
- Alchohol to gas
- How long stock 10 bolt will last?
- Too much power?
- paging Taner or RomanSS
- Congrats Matt Swindle!!!
- Quest for 11's with current set up?
- New Best...First 12-second pass! (video)
- watch this 305 kicks some a$$
- M/T ET Streets
- I want to run 8 flat in the 1/8..Help
- NHRA & Wheel Spacers?
- Timeing and Knock retard question
- 60 foot time not allowing 11s
- new best, 12's finally
- Starting Line Ratio
- Bang for the Buck Torque Converter Vs Suspension Mods
- Gears
- What stall with 4.56?
- U Think I'll Hit 11s????????
- who has modified their wiring harness/got rid of interior wiring?
- Question about Tire Size
- weight lose
- Which tires are better????
- Rim/Tires Questions, see here, please..
- Triming bumper spacers a good idea?
- subframe connectors
- Help me dip into the 12's
- Two quick questions about Telstars and other drag light wheels.
- anyone install a Jegster rollbar kit....4th-gen
- 4 point roll cage
