k-member - which one???
Old Apr 29, 2003 | 09:34 PM
speedmiser's Avatar
Who makes the best K-member for the LT1 f-bodies?
PA, BMR, others?
Most importantly - why?
I'd appreaciate any input on weight differences, strength, clearence issues, and ease of install.
Old Apr 29, 2003 | 10:25 PM
94-3.4's Avatar
I also just saw Jeg's is now offering a k member made by AJE Racing. Havn't heard of them before. Any experiences?
Old Apr 30, 2003 | 05:41 AM
RacinLT1's Avatar
I have the PA racing unit getting ready to go on my car. very light,and a solid piece. We have the PA on a friends 87,fit great opened up room like you wouldnt believe.
I have heard of BMR having fitment issues with Hooker longtubes,but not sure if they fixed that.
Old Apr 30, 2003 | 08:52 AM
speedmiser's Avatar
Racin,
What's the motor mount design like on the PAs? Are both (or either) integral, or are there provisions to bolt on the stock style motor mounts?
Old Apr 30, 2003 | 04:21 PM
RacinLT1's Avatar
PA can be ordered with or without provisions for stock mounts. i ordered mine for use with stock or solid mounts.
Old Apr 30, 2003 | 04:45 PM
speedmiser's Avatar
Is p/n 1203MM the one you have?
If so, Tbyrne has a damn good price. I may give them a call tomorrow.
Old Apr 30, 2003 | 09:05 PM
RacinLT1's Avatar
yes that's the part number.
Old Apr 30, 2003 | 10:09 PM
mongse_1's Avatar
I had a BMR and a PA Racing unit. Just comparing the welds on the two, the BMR looked much better. I had several spots in the welds were there would be small holes in the bead. Plus, none of the slag was cleaned off the k-member, it was just powdercoated over. BMRs looks like a little more care was put into it.
Just my $.02
Old May 1, 2003 | 02:35 AM
sleeperZragtop's Avatar
I had a friend buy a PA and he had wished he got a BMR...I have an LS1 but check out some pics in my sig...as for the BMR, value and workmanship is
Old May 1, 2003 | 08:41 AM
speedmiser's Avatar
mongse - do you feel that the PA is not structurally sound due to the welds and construction? Are they that bad? Or is it more of cosmetic/appearance differences in the welds between the PA and BMR?
I'm looking to buy either unit in black. And since it wont be all that visible, unless the car is in the air, I'm really only concerned about functionality, clearence, and weight savings. Doenst hurt that I can get the PA unit for about $60 less either. So at the moment, that the way I'm leaning, but I'd like to hear anyones thoughs and experiences.
sleeper - why exactly did your friend wish he had bought the BMR over the PA?
Has anyone with either the BMR or the PA had one of the K-members bend the tubing or break a weld?
Thanks for the reply so far guys...
Old May 1, 2003 | 08:49 AM
RacinLT1's Avatar
After seeing the htread,i got my k member out of storage abd looked it over again. Also we didnt see any issues with the 1 on my friends 3rd gen,and my buddies 8 sec Drag Radial mustang.
I dont see any "bad" welds or any excessive slag.
Only person that i know of that bent a PA racing unit was George Baxter when he stood the car on the back bumper,let off and came slamming down.
Old May 1, 2003 | 11:27 AM
speedmiser's Avatar
Thanks for the comments guys.
I've went ahead and placed the PA on order. Sounds like it will meet my needs.
Old May 1, 2003 | 03:27 PM
zturbo's Avatar
I have a PA on my car and will be swapping to a AJE. There products are very good from everything i have heard.
I have no issues with my PA setup and everything mounted fine. If you are going to need more pan area go with the AJE as it comes foward more.
AJE K members
They are all imo about the same it is just which design do you like most and what price deal you can get. ARE has one as well and not sure on the price but they were having a special a while back.
Steven
Old May 2, 2003 | 03:30 PM
mongse_1's Avatar
Since you bought it, it's a bit of a non-issue but I just didn't like the look of the welds. A friend of mine got his right around the same time for his LS1 TA and it had similar problems. Was it structurally sound? Probably. Did I want to take the chance...no really.
I used to have pictures that I took of the PA. I'll see if I can dig those up this weekend.
Old May 2, 2003 | 06:07 PM
speedmiser's Avatar
Well I bought it on a cc, so I if I dont like the looks of it, I can always return it
It was approx $380 (including shipping), and with those locally and those on the board who OK'd it's functionality, I figured it was worth a try. I'll guess I'll find out for sure, when it arrives
Thanks again for the replys.
