Cam suggestions?
Old Oct 20, 2003 | 10:54 PM
rje's Avatar
rje
Cam suggestions?
I'm currently runnning a 228/236 bullet cam and was looking to upgrade when I have some more port work done on my heads this winter. My engine is a 94 LT1 bored 0.030, forged Ross pistons, Eagle H beam rods, and the stock crank. I was thinking about going with a comp cams 236/242, but wasn't sure if that would put me turning to many rpms for my stock crank. Any suggestions would be great.
Randy
Old Oct 21, 2003 | 05:29 AM
Nostang 96z's Avatar
I run a 235 242 GTP-6 grind and mine pulls all the way to 7k. I do have Comp R lifters, stud girdle and an AFR rev kit though. I have the same basic bottom end as you and mine is holding up. BTW I shift at 6300 rpms...that rpm seems to do good for best ET.
Matt
Old Oct 21, 2003 | 07:08 AM
rje's Avatar
rje
Thanks for the info Matt. I've noticed your sig before and thought that it was quite impressive. I think I saw you at MIR earlier this month for the f-body shootout, but I didn't get to talk to many people with as hectic as everything was. Thanks again and maybe the next time I see you we can talk. Later.
Randy
Old Oct 21, 2003 | 09:45 AM
T/A lt1's Avatar
Two words for you "Custom grind" cam shaft is what you need. At your power level and what you are wanting to do you need something designed to work with your setup Call Joe Overton and he can hook you up with something that will make some more power. I did and I am satisfied. #804-598-9261. JMO Later
Old Oct 21, 2003 | 12:28 PM
Randy
Yup that was me in the PA class. It was a hectic day for sure. Next time come by and talk. BTW did you run your car that day. I did not see that many Lt1's down there that day but the LT1 cars were the fastest . T/A Lt1 is right about a custom grind and Joe O does know his stuff.
Good Luck
Matt
Old Oct 21, 2003 | 06:34 PM
rje's Avatar
rje
Thanks, I think I'll give Joe a call.
Ya, Matt I ran my car that day, it ran low 11.8's all day, it just wasn't enough to make the LT1 H/C class.
Randy
Sauced
Apr 12, 2015 10:18 AM
cobrakilling101
14
Mar 17, 2015 10:42 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
alex5366
Feb 17, 2015 08:12 PM
alex5366
Feb 17, 2015 09:07 AM
