bfg drag radial hooks better than et street
I just switched from a 275/60/15 bfg drag radial to a 28x13.5x15 MT E/T street and went from a 1.701 60' to a 1.889. Can anyone clue me into why i droped almost 2 tenths in my 60 foot?
I would say that you need some t&t time to learn the tires. I run 26-10.50x16 ET streets and pull consistant 1.70 60s in the summer heat. 16 psi cold, pretty hard burn out especially the first one for the day.
But then Drew could be right. You went to a 28" tall tire which reduces your effective gear ratio at launch. Just spray it out of the hole
The rim spun? Try some rim screws. That could certainly be a problem. Also, you want the highest amount of air that doesn't allow the tire to spin. Were there any unusual environmental conditions? At your power level I would normally be suggesting a 26" tire.
I would run a 26 inch tire if i wasn't already going through the traps at 5400rpm on motor in 3rd gear on a 3 speed trans. On the gun i am tapin the revlimiter right before the traps.
How do the ET Streets compare to the BFGs in terms of driving on the street? I am trying to find a good tire that I can throw on my 15" bogarts permanently and drive on daily and on the track. I want something that will handle OK and get me into the 10s on the track. Was thinking about the BFG 315/60r15s or the 28/10.5/15 ET Streets or maybe the QTP Hoosiers. I heard the right set of BFG DRs can get you into the 9s... They put a Supra into the 8s. Any advice?
You want to talk about reducing the effective gear ratio, I am running 28" tall tires w/ 2.73s. (times in sig on street tires) I think they may actually help though b/c I shift into 3rd right before the finish and without them it is more like 50' or so.
If you spray out of the hole and everything works right you should be running high 1.4 60 ff times.
No way BFG's work better.
Either you bogged (on motor) or something was not right.
I would not run those slicks below 15 psi cold you don't need to with the power you have.
I went 1.48-1.60 at US41 all day long on 28x10.5x15 Hoosier slicks, 15psi cold, fron hals at 2/2, and rears at 3/4.
www.mfba.org has our annual shootout at US41 tomorrow c heck out the events section on the message board.
If the weather is good I'll be spectatin' and I'd be glad to spot your car and let you know how it works off the line.
Here is me last year:
http://www.pbase.com/image/5269912
