14.68@100.7 whats wrong?
Old Oct 13, 2003 | 10:32 AM
NeoSNK's Avatar
Thats the best I can do, car runs great. All new ignition, new tires. The time is on the g tech. My mods are cai and tb bypass. Engine has 132k miles. I've changed the tranny filter. I'm thinking fuel filter next. Any other ideas?
Old Oct 13, 2003 | 10:50 AM
NeoSNK's Avatar
Theres guys running 14.0 at 97 which is the same mph I'm running, gtech is 2-3 mph higher than a track. I launched at full throttle with no wheelspin. I guess I should go to a track and see. Its just always bothered me that the g tech says 14.6 I've tried it many times on different days.
Old Oct 13, 2003 | 11:39 AM
TedH's Avatar
Why don't you take it to the track and find out for real?
Old Oct 14, 2003 | 06:21 PM
94GrayV6's Avatar
How is it possible to launch at full throttle in an AUTO? Do you mean just flooring it when the green lights up?
If you can floor the car and it won't spin street tires, then it's missing alot of power.
Get a tune up.
Old Oct 14, 2003 | 10:20 PM
GJE94Z28's Avatar
Wink
You really need to take it to the track and get some baseline runs. Then the mods begin...
Old Oct 15, 2003 | 12:45 PM
How sure are you that you were on a perfectly level road? How sure are you that you had the g-Tech correctly aligned on all 3 axes? Both of these can screw things up. I think the estimate of the g-Tech being 2-3 MPH high is optimistic... I've seen them off by as much as 6 to 8 MPH. ET is usually within 2/10's though, assuming you were on a level road. It's really not an accurate way to estimate track performance. More useful for establishing a relative baseline, then comparing the results of any changes.... did it make it better or worse? But it isn't necessarily going to tell you how it runs at the track. And, even when evaluating the affect of changes, you need to always use the same stretch of road, and correct for ambient conditions.
Old Oct 17, 2003 | 02:36 PM
Derrick Redd's Avatar
Ditto.
Old Oct 17, 2003 | 08:30 PM
stereomandan's Avatar
Here's the situation. The G-tech measures your speed at the exact 1/4 mile mark.
At the track, it is averaged over the last portion of the track, which makes the mph numbers a little lower.
The G-tech will always read higher because of this.
Sounds like you had a fairly bad launch, but the top end seems about right if you drop about 2-3 mph off.
Dan
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
