Best Air for Racing
Old Sep 11, 2003 | 03:22 PM
Like My Taillights?'s Avatar
Best Air for Racing
Does anyone have opinions on what the best air temp/humidity is for racing? It's getting to be fall here in New England and I'm waiting for that perfect day. Any help would be appreciated. Thanks!
Old Sep 11, 2003 | 04:02 PM
96z's Avatar
96z
Low temp maybe low 50's, low humidity, and high pressure. Track elevation plays a huge roll also.
Old Sep 11, 2003 | 04:32 PM
KEITHZ06's Avatar
New England Dragway is at 90' above sea level if you run on a saturday test and tune on a sunny fall day with low humidity you will hook up and run fast.It is not uncommon to se the DA below sea level in the spring and fall. I jast ran a tenth quicker than I had all year 2 weeks ago.
Old Sep 11, 2003 | 05:01 PM
RamAir95TA's Avatar
For horsepower, cold weather.
For traction, hot weather.
Find a happy medium.
I only race in the winter and late fall months for the most part.
Old Sep 11, 2003 | 08:04 PM
Stephen 87 IROC's Avatar
Although the cold/cool temperatures are desired, you don't want a cold track. The track has to be warm but not hot. During the summer, traction will improve when a cloud goes over and blocks the sun.
Old Sep 12, 2003 | 06:07 AM
Raptor1's Avatar
Going by what's in your sig I guess that your car is basically stock.
IMO, LT1's that are stock to lightly modded run best when weather is:
Air temp. - 58-62 degrees
Relative hunidity - 35% or less
Dew point (often overlooked) - 30 degrees or less
Barometric pressure - 30" or higher
If the sun is out track temperature shouldn't be a problem as long as the air temperature is 58-62. If it's cloudy with a breeze it may be a problem, depending on how well the track is prepped. Watch some of the faster cars to see if they're having any problems with traction. If they are, wait for a while until the track gets some heat in it from other cars making runs.
Good luck!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
95chwagon
Jan 13, 2015 09:19 PM
