Going tubless. Do I need valvestems?
Old Oct 24, 2003 | 07:14 PM
94irocz's Avatar
Might sound like a dumb question but I figure I do. If I do what kind do I need for some 15x10 pro stars? Thanks
Joe
Old Oct 24, 2003 | 07:27 PM
Stephen 87 IROC's Avatar
Just the normal short rubber valve stems will do HOWEVER,
General regulations 5:1
Metal screw-in valve stems manditory in tubeless tires, front and rear on cars running 11.99 and quicker.
You're only running high 12's but since you're going to have the tires off anyway, install some metal valve stems now and forget about them.
Old Oct 24, 2003 | 08:24 PM
94irocz's Avatar
Thanks man got a part # for me or anything there are a couple different metal valve stems in summit. And thats high 12's now hopefully low low 12's next friday
J D
Old Oct 24, 2003 | 10:28 PM
SUM G-1957 is what you need to pass a tech inspection or some other manufacturer with a similar valve stem. Check your local parts supply store. Don't forget, all tubeless tires must have these stems including your steering tires.
SUM G-1958 looks cool on a custom car but is a pain to constantly check tire pressure. You need to use the special adaptor every time you want to check the pressures. I had them for a while then switched to the proper style.
SUM G-1955 is just a standard rubber valve stem with a pretty chrome sleeve. It won't pass a tech inspection.
Old Oct 25, 2003 | 09:24 AM
94irocz's Avatar
THanks man just what I was lookin for. Much appreciated.
Joe
rel3rd
Dec 2, 2012 04:23 PM
BoozrCruzr
Feb 26, 2007 10:40 PM
1 Nasty Bird
Wheels and Tires
May 28, 2005 11:54 PM
chevyguy3
Aug 18, 2003 10:37 PM
