just bought a S&W roll bar
Old Oct 20, 2003 | 07:11 PM
1994TransAm's Avatar
hey there,
i just bought a S&W roll bar. anyone have these?
how do they fit, any tips on the install?
Old Oct 21, 2003 | 12:32 AM
MBonZ28's Avatar
the S&W requires a lot of triming. good thing is you can make it fit around you and your seat. they take some work though
Old Oct 21, 2003 | 07:49 AM
Since its all cut and weld, I'd suggest you get a copy of the NHRA (or IHRA) specs for roll bars. They are very specific on location of various components relative to the seat and driver, how they attach to the floor, etc.
Old Oct 21, 2003 | 09:28 AM
red's Avatar
red
The only bent pipe in the kit is the main hoop. You will need a way to cut, notch and bend the other pipes. I will also assume that you have access to a mig or tig welder. I did all my notching with a grinder and it took a very long time. If you have the money get a tube notcher. It will be a big help.
Old Oct 21, 2003 | 03:24 PM
The Big Show's Avatar
I had one a few years back in my green car. I just put a comp engineering bar in the car this past weekend and it was basically identical to the S&W bar. Everything that was said in this thread is true...hence the price of the bar compared to one from Wolfe or the likes that is basically already pre-cut for a 4th gen. The tubing notcher will save you hours, and I do mean HOURS of work so even if this is your first install its worth it. Just take your time and you'll be pleased with the results.
Old Oct 27, 2003 | 09:02 PM
quick91rs's Avatar
Post
My S&W roll bar for my 3rd gen came pre-notched except for one end of the bar which runs behind the seat. If anything needs to be shortened, you cut the end that's not notched. Did S&W quit notching their tubing or something? I bought it 4 years ago.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
WildRidez
Feb 23, 2015 07:24 PM
quick91rs
Sep 4, 2002 08:22 PM
twistedwedge
Jul 27, 2002 01:54 PM
