Are Video 8.54@167.33 !!
Originally posted by Notford95
Indeed, that was an awesome run.
SecretZ: Are your times legit?
Hey Sled,
That looked like a real good drag race between Wade and the Ford.
I was watching Wade's pass and at the end of the track just before the video ended and I got a flash back of a scene that resembled yours that I have watched to many times when we have been at the track running? Did you guy's burn a piston or hurt the motor?
PS Get my motor done.
See YA,
See YA,
Again, I ask: WHEN THE DEVIL DID THE EIGHT SECOND BARRIER GET SURPASSED (LT1)????
Again, that ARE LS1 is rather quick as well, but come on...that is four tenths of a jump with no warning whatsoever.
Injuneer, Any input?
Matt
Matt
Matt
Matt
Fred
The fastest 4th Gen, an LT1 to boot, is sitting in a garage in VA as we speak. Some more NA track sessions are probably still in the plans, but the fogger is waiting to go on.
So far he is the fastest 4th gen LT1 NA......but soon to take the crown for all 4th gens. Joe is the man....
http://hometown.aol.com/one94ta2try/...onetawheel.jpg
JWINN, do you have a video of my car? I don't follow you 100%...
As for the ARE Silver Z......
The motor is ok, its normal for the car I'll try to explain...
When Wade crosses the line he lets off the throttle and pulls the chute. The tranny we have goes into neutral (freewheels) whenever there is no throttle being used. So the RPM's come down to idle, which makes the vacuum pump almost not working. The vacuum pump is RPM related with a belt off the front pulley. More RPM, more Vacuum. When the chute hits, it nosedives the car, bottoms it out actually, and all the oil gets pushed to the front of the motor allowing the rods to pick it up and shoot into the front bores making it smoke since there is no vacuum and lots of pressure buildup. The front plugs always look different then the others. This track also has a short shutdown, so the chute is deployed right away at basically full speed to get it to slow down in time for the upcoming corner. Some smoke also comes from tire rub when you get out of it and the tire distorts.
Matt
Matt
CARiD
Sep 30, 2015 05:44 AM
cmsmith
Sep 14, 2015 09:09 PM
mark0006
Sep 14, 2015 12:35 PM
