BFG Drag RAdials Comp T/A
Old Oct 13, 2003 | 06:50 PM
JKDZ28's Avatar
i have BFG Drag Radial Comp T/A 255/50/16
what is a good air pressure for the track to hook?
Old Oct 13, 2003 | 08:13 PM
RacinLT1's Avatar
there is no set pressure,as every car and track dictate different setups. try around 20 psi and go up or down from there.
Old Oct 13, 2003 | 09:15 PM
JKDZ28's Avatar
thanks dude..
i was pretty much looking for a ballpark pressure range
Old Oct 14, 2003 | 06:09 AM
Raptor1's Avatar
I'm with RacinLT1 on this. I'm on my 5th set of those same size tires. I usually use 18-20 psi if the track is prepped half way decent and I hook good. I do a good HOT burnout and they stick like glue
Old Oct 17, 2003 | 11:52 AM
supermo26's Avatar
I was wondering why the 255 sized tire? Would you hook better with something a little wider?
Old Oct 17, 2003 | 12:24 PM
CanIroc's Avatar
That's as wide as they make them in a 16" wheel.
You can always go to an ET Street!
Bob
Old Oct 19, 2003 | 04:34 PM
JKDZ28's Avatar
if i went with ET STREETS i would have to kiss my rearend good bye
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
