hal/qa1 vs. kyb
Old Sep 9, 2003 | 06:46 AM
lt1camaroman93's Avatar
hal/qa1 vs. kyb
Is it worth the extra money to get the 12 way adjustible hals over the much cheaper kyb? also if i go with the hal's should i use their springs or get a drag launch kit?
Old Sep 9, 2003 | 09:37 AM
speedmiser's Avatar
KYB AGX shocks wont go any softer than stock. Heavier yes - softer no... So for drag racing, the AGX's are basically garbage (at least on the front end). How do I know??? Justed replaced a set of AGX's with Qa1s and the Hal drag springs. Sorry, but there's just no comparision - the Hals are definetley worth the money
I'm running a non-adjustable shock in the back with cargo carrier springs and an airbag in the pass rear. But if you wanted to go adjustable on all 4 corners without ponying up for a full set of hals, you could use hals in the front and CE's in the back. You'd spend just a little more than AGXs all the way around, but you'd have a much better setup - IMO...
BTW, in the past, I didnt care for the extreme rake my car had with 28" rears and 25.7" front runners - I was able to adjust the height of the front end with the hals (no can do with the kybs) - looks much better now, plus I dont scrap the front air damn pulling out of my driveway anymore
Old Sep 9, 2003 | 10:24 AM
89ProchargedROC's Avatar
buy the strange 10 way adjustable rear shocks....$60 a piece. I know a racer using those with double adjustable front struts and is pulling mid 1.30s 60 foots
www.billingsleyracing.biz
they carry them and sponsor camaroz28.com i believe
Old Sep 9, 2003 | 10:40 AM
I already have the CE 3 way rear shocks. just looking to do the fronts now. So i guess i will shell out the extra cash and get the hal's. should i use their springs or get a different set?
Old Sep 9, 2003 | 10:57 AM
speedmiser's Avatar
Go with the Hal drag springs - they are made to fit the qa1 shocks and work very well.
If I rememer correctly, if you dont use the hal springs you'll need to run some type of adapter to seat the bottom of the spring on the shock mounting point (which is right above the double adjuster)
Old Sep 9, 2003 | 02:35 PM
depends on how streetable you want the car though. Most people i know with the front hals and front hal drag springs say they are too soft for everyday driving
Old Sep 9, 2003 | 03:57 PM
speedmiser's Avatar
It does float the front end a bit over dipps on the lightest settings, but I've driven it to work that way a few times now and it's no big deal... and I imagine I could adjust the shocks over to the stiff side and get a much more firm ride.
I guess different folks have different ideas as to what's streetable .
Old Sep 9, 2003 | 10:26 PM
What are the chances of me getting the front wheels off the ground with me running a 1.701 60' as i sit if i switch to hal's with hal drag springs?
Old Sep 9, 2003 | 10:30 PM
also, are the springs that bmr sells with the hal shocks their drag springs???
Old Sep 12, 2003 | 11:59 AM
dobe's Avatar
I'm gonna be running the QA1 shocks and their drag spring up front on my daily driver... so i hope it wont be too bad of a ride
NewsBot
Jul 3, 2015 02:10 PM
ModdedNerd
Feb 5, 2015 04:37 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
