Looking For People That Have Gone To Manual Brakes In A 4th Gen
I am curious what all is involved and if you have any pictures of the change. I see that Billingsley has a manual master available, but what about the ABS module. Does that whole thing get ripped out??
Any and all help is appreciated.
Hay Nick, check out Brady McNews site he has some good info/pics of what your looking to do.
http://www.turbocharged.net/twinturbo/
I have a done this a couple of times.
When I first did my Firebird I used the factory master cylinder mounted to a 1/2" aluminum plate. I later switched to a early eighties S-10 master cylinder which takes less peddle pressure than the factory one.
On my Camaro I bought my whole master cylinder assemby from Pete-Z. It uses a mopar style master cylinder and works perfectly. It also includes a brace which goes to the back of the wheel well.
Both ways work fine. The S-10 route is cheaper, but the Pete-Z looks cooler. Either way, use a brace to stop the firewall from flexing.
Good Luck,
Daren
Good Luck,
Daren
just curious, but what's the advantage of going to manual brakes? i know if you run a large cam with lots of overlap, you lose vaccum, but why not just put a vaccum booster on? Does this save a lot of weight? I always thought it was harder to stop with manual brakes. Please inform me, i'm trying to lay down a plan to completly re-do my car into a bitchen street/strip car.
This is a picture of the Pete-Z set-up on my 1999 Camaro C/SA. I will try to find Pete's phone number and post it.
As far as manual brakes go, you are using the same brakes, it just takes more human power to stop. My first car was a 1969 GTO with four wheel manual drum brakes. Now that was another story!!
Good Luck!!
Daren
http://www.ls1tech.com/nvss/pages/DSC01295.htm
Good Luck!!
Daren
Jul 4, 2005 05:00 PM
JasonD
Jul 15, 2002 02:17 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
