tunercat with mark 8 fan
Old Jun 16, 2009 | 08:51 AM
balljoint's Avatar
I put a 94 LT1 in my 68 with mark 8 fan. i wired the fan to the pcm`s primary fan A-11 an 75 amp relay. I have 160 T-stat and want to set the fan to come on at 180. I have no idea how to do this with my tunercat.
Old Jun 16, 2009 | 10:48 AM
bobdec's Avatar
Go to the "Fan Enable Cooling Temp Vs. Speed" table and set the Fan 1 settings (High and Low) to the temp that you want the A11 pin to go active (0V). With a 160* T-Stat, mine is set for 79.25*C that's 175*F. It gives the T-Stat a chance to be wide open before you turn on the fan. If you set it much lower you could be wasting energy needlessly pushing the fan against a closed or partially opened T-Stat whenever the engine is running. The Fan 2 settings are not important as your setup has nothing wired to the A10 pin.
Old Jun 16, 2009 | 04:17 PM
balljoint's Avatar
thanks bobdec. Just realized I have to use the EEB program and not the EE because I have the early 94 pcm. There is no "Fan Enable Cooling Temp Vs. Speed" table in the EEB. Now what.
Old Jun 16, 2009 | 04:25 PM
balljoint's Avatar
Wait a minute, I found the "Fan Enable Cooling Temp Vs. Speed" in the EEB table. Its in the 3rd column at the end. Many thanks
Biggiebound
Apr 23, 2015 08:50 AM
NewsBot
Apr 7, 2015 10:50 AM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Dec 7, 2014 11:32 AM
Z284ever
57
Aug 4, 2002 03:48 PM
