Need some help... OBD2 port isn't powering up?
Old May 14, 2009 | 05:41 PM
RealQuick's Avatar
took the T/A and got to see the boost gauge in action (digital).
1st gear - as soon as I hit 0psi the tires break loose.
2nd gear - as soon as i hit 1psi, the tires break loose
3rd gear - as soon as i hit 5psi the tires break loose
4th gear - I hit about 8psi around 4500rpm and i got off it because it is too fast for public backroads.
The one problem i have is my OBD port on the car isn't powered up. I hooked up an OBD2 scanner (which blinks if there are no codes), and it never turned on. this is why i can't get my tunercats to read. any ideas?
Old May 14, 2009 | 06:18 PM
moparman's Avatar
Check the fuse for the port. It's on the same circuit as the cig lighter.
Old May 15, 2009 | 10:41 PM
RealQuick's Avatar
Thanks for the help... it was the 25A fuse!
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
pimpss96
Feb 12, 2015 01:28 PM
XtremeLt1
Sep 13, 2002 08:50 PM
