Running rich codes PO175 and PO172
Old Sep 17, 2009 | 05:25 PM
bsommerf@aol.co's Avatar
Unhappy Running rich codes PO175 and PO172
I've read most of the running rich posts and didn't find this. 2002 Z28, Service Engine Soon light is on. The 02 sensors are fine, had the MAP sensor replaced and now replaced the mass air flow sensor. Same deal. It's running rich about 15 on the scope. It runs fine, doesn't smoke, gas mileage around 20-21mpg combined.....anyone had this problem or have any ideas? Thanks.\BluewaterBill
Old Sep 18, 2009 | 09:24 AM
LearJet's Avatar
Clogged cats perhaps.
Old Sep 19, 2009 | 06:43 AM
What do you mean by "about 15 on the scope"? Do you mean the A/F ratio is about 15:1? If so, that's not rich. Its very close to the stoichiometric A/F ratio of 14.7:1, which is where its supposed to be in closed loop (idle, part throttle/moderate loads). If it's 15:1 at WOT it's running lean.
It is possible for the engine to be running at the correct closed loop A/F ratio, and still set the "rich" codes. The PCM uses the long term fuel corrections to keep the engine operating at 14.7:1. The codes mean the engine would be running rich, IF THE LONG TERM CORRECTIONS WEREN'T BEING USED. The long term fuel correction are limited as to how much fuel they can pull out to correct a rich condition. When the corrections approach their limits, the codes are set.
Have you checked the fuel pressure?
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Dec 1, 2014 08:08 AM
jrp4uc
43
Sep 18, 2002 08:26 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
