FreeScan vs. DataMaster ?
Old Aug 18, 2009 | 07:53 PM
HardcoreRM125's Avatar
So I downloaded the Trail Version of Datamaster as well as FreeScan.
Waiting on a Lap Top battery so I can go actually use them and do some logging/tunning on my car ...
Why do some people pay the extra $$$ for Datamaster? It seems to display the same info as FreeScan? Just does it in a "neater" package.
Is there anything you CANT do with FreeScan but are able to do with Datamaster? I will spend the $$$ if it is worth it, but I feel like $100+ is not worth giving me the exact same information just in a more 'presentable' way ...
Thoughts?
Joe
Old Aug 18, 2009 | 09:22 PM
Record and playback are the things I like about Datamaster. I can't remember what Freescan has. I only used it a couple of times years ago.
Old Aug 20, 2009 | 10:32 PM
97 RedSS's Avatar
Datamaster rocks!
Old Nov 30, 2009 | 03:09 PM
khojo16's Avatar
can datamaster be used for 96-up? i was on their website to download the software, and it is only available up to 95 F-body...
Old Nov 30, 2009 | 11:36 PM
TTS DataMaster is only for OBD-I (93-95)
I doubt many people pay anything for DataMaster. They just use the 20 free runs.
I've reviewed data files from both systems and they are similar, particularly when you review them in Excel format, which I find to be the best way to review them.
Old Dec 1, 2009 | 01:33 PM
The Untouchable's Avatar
do u have a link to the data master and free scan download ? and how do u import the data into excel?
Old Dec 1, 2009 | 04:45 PM
94ZRagtop's Avatar
Datamaster:
http://www.ttspowersystems.com/DataM...downloads.html
Freescan:
http://www.andywhittaker.com/ECU/Fre...0/Default.aspx
Freescan saves as a .CSV /text file, so you can import it in to Excel as such (though I prefer OpenOffice, as it's free ).
I am going to be testing Datamaster 3.6.0 tonight. Not many changes, but it fixes the Vista quirks and trying to get it to run cleanly with Windows 7.
Old Dec 1, 2009 | 04:59 PM
TTS DataMaster has an "export" function, that allows you to define the data columns you want to export, and to export them as a .csv file. The standard DataMaster file has a .uni extension, which requires DataMaster to play back.
Old Dec 1, 2009 | 06:55 PM
Originally Posted by 94ZRagtop
Datamaster:
Freescan:
thanks guys , i didnt even realize tts made that as i have dealt with them with the diesel stuff
Old Dec 2, 2009 | 08:55 AM
Wild1's Avatar
So does Freescan only work with Windows XP? Not Vista or 7?
Old Dec 2, 2009 | 11:02 AM
94ZRagtop's Avatar
It ought to work fine under 7, maybe I can test it tonight.
Old Dec 2, 2009 | 08:39 PM
MaximumJavelin's Avatar
Freescan works with the newer OSes, I've used it on Vista and am currently using it on Win7 x64 without issue.
I haven't really played with datamaster but it looks like it has more logging of transmission data which is nice for an A4. It also has some pretty cool features built right in which can make it easier to figure out what's going on if you're not proficient with using Excel or other software to analyize your own data. Freescan is always a good place to start though and if you find yourself thinking "I wish I could do more" then take a look at datamaster.
Old Dec 2, 2009 | 09:48 PM
WS6T3RROR's Avatar
I have yet to figure out how to log a wideband with freescan. That is the only advantage I can really think of for datamster, other than I am just more comfortable looking at the info in the format they present and I can set up graphs to check for trends when certain conditions are met without scrolling all over the place or locking a pane in excel. The auto trans functions are nice as well you can see when the shifts are commanded vs when they occur and what exactly goes on during the shift.
Old Dec 4, 2009 | 02:09 AM
96 WS6's Avatar
All it would take is for freescan to log the a/c pressure sensor voltage (0-5v). Then you can easily use a 0-5 linear wideband output and simple equation to convert in excel. I wish...
Old Dec 4, 2009 | 07:06 PM
94ZRagtop's Avatar
Tested Freescan with Win7 Enterprise (32-bit) tonight, it works when you "Run As Administrator". Doesn't work in normal user mode. This is using one of my USB/ALDL adapters.
Bails098
Aug 17, 2015 05:15 PM
NewsBot
Jul 3, 2015 02:10 PM
JeffK95Z
Nov 13, 2002 12:50 AM
Dave 96TA
Sep 24, 2002 04:10 PM
NVR2QIK
11
Aug 23, 2002 05:33 PM
