Bin file for LT4 needed
Old Jul 18, 2009 | 08:24 AM
MichiganSkip's Avatar
I need a TC or LT1edit flash for a stock LT4 96 if anyone has it. I need the 28# injector offsets/battery voltage values
thanks
Old Jul 18, 2009 | 08:28 PM
ACE1252's Avatar
Check the tunercat files section.....
http://www.monodax.com/forums/
I found this on there in just a few minutes of looking....it's not a bin, but a .cal
http://www.monodax.com/forums/tunerc...t4-m6-cal.html
You will need to join the forum to get it.
Old Jul 19, 2009 | 08:27 AM
Thanks, I am a member there too. I need a bin file, but the 96 is obdII and I can't open it in TC obdI. I need to go another route to find the values to plug in the injector offset vs. battery voltage table for 28# injectors.
Old Jul 19, 2009 | 08:43 AM
did that already, also saw those files. Plus I got scolded for not "searching" first. I don't know how people seem to think we don't search first. If we found what we were searching for, we wouldn't ask now would we? I need a .bin file, not a .cal file but thanks for helping out anyway
What I am looking for specifically is the values for a 28# injector, that go into the "injector offset vs. battery voltage" table in TC OBDI version. I have a 95 Z28 that I swapped the 24# Multecs out for 28# Bosch III injectors,
Old Jul 19, 2009 | 12:30 PM
Stl94LT1's Avatar
I have a .bin file that says LT4. I don't remember where I got it, but the injector offests are definately different than the stock LT1's. I could send it if you would like.
Old Jul 19, 2009 | 05:09 PM
Got one! thanks though
Parts Wanted
Mar 17, 2015 11:24 PM
NewsBot
Jan 21, 2015 06:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
NewsBot
Dec 3, 2014 12:30 PM
