BLM Locker
BLM Locker
Hey guys, curious about the BLM locker patch and how to get it to work properly. I downloaded the .ZIP file and installed it. Is that all that is required or is there something I have to do in Tuner Cat to get it to function properly? I didn't notice any new cal tables or constants.
You have to run the tune file you're using through the locker program and it will modify it so that they go to 128 when you enter pe mode no matter what they are before that.
It has nothing to do with tuner cat at all it is not an add on.
It just unzips to a folder there is no actual install. Its just an exe file that will change a couple of hex values in a tune file. Maybe you could try a search for blm after you unzip it to find its location.
You don't have to do any of that if you use Tunercat. Just ask TC for the EEL definition file so that Tunercat will lock the WOT BLMs of which ever file you save with that defintion file. Then if you don't want them to lock, use the regular EE file.
Dan K
Aug 28, 2002 12:06 AM
