code29 Can anyone help with diagnostics on this .
Old Jul 18, 2009 | 08:01 PM
ziggy0611's Avatar
I have a 1995 z28 LT1. It is storing a code 29 eas electrical circuit fault (QDM). I do not know what eas is. I was thinking that qdm might be quad drive module. The chevy dealer down here says they dont even show that code in there book. When the code sets both cooling fans come on also. Can anyone help explain what this code means. I am a ase certified mechanic but never heard of this code.
Old Jul 18, 2009 | 08:16 PM
ACE1252's Avatar
What is telling you the code is 29? Also, where are you getting your descriptions? According to my info(Haynes manual)code 29 is.....
"Secondary Air Injection problem - Check the secondary air injection (AIR) system for an open circuit in the wiring.".
Old Jul 18, 2009 | 08:22 PM
ACE1252's Avatar
Thread with Code 29....
https://www.camaroz28.com/forums/sho...hlight=Code+29
Shoebox's code reference page....
http://shbox.com/1/Dtcs.htm
Old Jul 19, 2009 | 10:01 AM
Check the fuse for the AIR pump.... it's blown. If the fuse continues to blow, there is a "recall" on the AIR pump system (95-97 only) and they should fix your system for free.
While you're at it, find a Chevy dealer that knows his butt from his elbow. There is no excuse for such incompetence.
Old Feb 14, 2011 | 02:53 PM
SATANAZ666's Avatar
Cool Re: code29 Can anyone help with diagnostics on this .
yEAP tHank you Ejuneer ma dawg! I had the same code and it indeed was the fuse for the Air pump!
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
MichiganSkip
Jun 8, 2015 10:30 AM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
silicuda
Pacific
Mar 5, 2003 03:14 PM
