Can ABS light be deleted from PCM?
Old Sep 29, 2009 | 09:07 PM
onefastmx5's Avatar
I'm looking into a s60 rear and don't want the 3-channel for the ABS. Since it will be unhooked, I'm assuming the PCM is going to throw a code or ABS light.
Can I buy a program like tunercat and delete the ABS function all together? Can I also change the gear ratio the PCM knows as well with it?
Thanks,
James
Old Sep 29, 2009 | 11:06 PM
The ABS has it's own computer. You'll have to find something that will communicate with it. I don't know if it is programmable. You won't get a trouble code from the PCM, but probably an ABS INOP light.
Old Sep 30, 2009 | 06:34 AM
onefastmx5's Avatar
So I'm guessing the fix is to remove the bulb for the ABS inside the dash??
Old Sep 30, 2009 | 09:59 AM
jsetzer's Avatar
Or cut the wire giong to it... you will probably get the red brake light too. Both are on in my car.
DirtyDaveW
Dec 1, 2016 05:37 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
cmdeshon
Dec 27, 2014 10:06 AM
