BLM question Park vs. Drive
We need to know more about your setup to get into specifics.
It is the same for me. When you have all of your idle air going through the IAC and idle plenum, the air is controlled better at each individual cylinder. This is what happens in park and no throttle if your blades are set up to be completely closed.
Now you give it some gas and air goes through the TB blades, it cannot be so easily controlled at part throttle to go to each cylinder evenly. The vacuum causes this. The larger the cam (reversion back into the intake plenum) the larger the split.
At WOT, you have atmospheric or close to atmospheric conditions so again this issue with split BLM's goes away.
Ben
Ben
Ben
Ben
jb4xx
Feb 2, 2015 10:00 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
