pcm
Old Jul 25, 2009 | 03:35 PM
noolah123's Avatar
pcm
I had a meltdown in my car with the alternator, had the system checked and the guy said, with no certainty that the pcm may not be sending power to the alternator causing it not to charge the battery. Anyone ever hear of that before?
Old Jul 25, 2009 | 05:13 PM
The PCM does not do that.
Old Jul 25, 2009 | 05:52 PM
noolah123's Avatar
any ideas what could be the cause? excitor wire has continuity, tried 3 alts, new battery installed, all fuses good.
Old Jul 25, 2009 | 10:17 PM
You are getting voltage on the exciter wire?
Old Jul 26, 2009 | 03:42 AM
noolah123's Avatar
low voltage. we tested it and got 1 volt.
Old Jul 26, 2009 | 03:53 PM
There is something wrong with that wire, then. You should be getting 12v with the key ON. The alt won't turn on without that voltage. It comes from the cluster and has a 470 ohm resistor in the circuit. The resistance must be there.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
