Why would the cylinder volume be off?
Old Jul 16, 2009 | 08:13 PM
94zgreenmachine's Avatar
Like the title says. I had the car tuned for a 383. My cylinder volume is set at 717.25 which should be the stock size. When I calculate 383 out , I get 784.52.
What gives? Why would this be?
If the cylinder volume changes in the program, would this change anything else?
Old Jul 16, 2009 | 08:16 PM
irocbsa's Avatar
Who did the calibration? Sounds like you need to get your money back. The forgot to changed the cylinder volume cal. 784.53ml/cyl is the correct number.
Old Jul 16, 2009 | 08:53 PM
I won't name anyone, just yet. I am keeping tabs of things . The tuner is well known on these boards, but more about that later......
By changing this value, will it automatically change other settings?
Old Jul 16, 2009 | 09:06 PM
irocbsa's Avatar
No other cals will directly change as a result of changing cylinder volume. However, if you have made other cal changes (VE tables, extended VE tables, etc) the fuel delivered will likely be incorrect now.
Old Jul 16, 2009 | 09:17 PM
I have'nt changed anything but I am not sure of what the tuner did.
I mentioned to him a descreened MAF. (wish I never descreened it)
Would you mind looking at the bin file?
I really wish I could get a stock bin file for a 94z28 a4. I searched Monodax and got a few and each one had been different, so I still don't know what is stock. Just to compare the 2 would be nice.
Old Jul 16, 2009 | 09:27 PM
Stl94LT1's Avatar
I have a stock file for a 95 A4 TA, if you want to compare.
Old Jul 16, 2009 | 09:31 PM
You have a PM.
Old Jul 16, 2009 | 09:44 PM
Stl94LT1's Avatar
email sent.
Old Jul 17, 2009 | 12:20 AM
WS6T3RROR's Avatar
If you're not running in speed density mode its not going to do anything at all.
Old Jul 17, 2009 | 04:58 AM
Once the tune is done, I wouldn't mind trying speed density. I have VE master but am a LONG ways away before I even attempt Speed Density.
Old Jul 17, 2009 | 05:52 AM
irocbsa's Avatar
Yes, I should have qualified that. I listed air meter curve by mistake. Changing it wouldn't make a difference. First post has been corrected.
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
